I live in the midwest where winter sucks....already in the 20's here. Anyways, was wondering if you guys starve out your carbs before storing. After adding Stabil and topping off the tank, I turn off the fuel and let her run until she quits. But is this necessary or better to not do it.....your opinions. Thanks
Im in Canada and find that most dont understand how to winter store a bike or summer store a snowblower or pretty much anything .
The confusion usually starts when we all go out and purchase " fuel stabiliser " . This stuff is great and will keep fuel fresh for many months.
The problems occure when the stabiliser is poured into the fuel tank but not run through the carb.
Its the carb. that needs it most so after pouring it in the tank you must run the engine to ensure it has reached and filled the carb.!
I suggest that a carb. bowl be removed and cleaned every year , with or without stabilizer as there will usually be some crap in it . Your choise .
I fill the tank, add Stabil and either run the motor with the petcock off until it stops or pull the plug at the bottom of the carb (S&S) and drain it.
Oh, and one other quicky…..w/o stirring up another oil thread, I'm about due for an oil change. Any ill effect on these evos if I were to wait until Spring to change it?
I've always changed my oil in the spring. I know that people say that you should put it away with clean fluids. I've never had an issue and I've doing it this way since 1998 in my flht.
Isn't the issue not changing it in the spring due to condensation inside the engine over the winter? I've always been a stabil in the tank and make sure it finds its way to the carb. If the carb isn't empty it won't gum up if stabilized. If empty little bits can evaporate over time and cause issues.
Hey Hackster, why not just leave the battery in the bike?
In my case, the garage sees frequent excursions below 0 F. in the winter, and a discharged battery can freeze. Better to be safe and pull it.
I've always changed my oil before storage, then changed it in the spring at the next scheduled interval. This year, winter has come early, and the bike is STILL at the shop waiting for the painter to paint the rear fender (going on 8 weeks), so I don't expect to get the chance to change the oil this year.
I don't drain the carb before storage, but I do remove the float bowl in the spring and empty it out before starting the bike.
I've always had bad luck whenever I've pulled a battery. I just leave it in on a tender….never had an issue. Getting back to the oil thing….I also run my bike up to operating temps once or twice during the cold winter. With or without fresh oil, has this been a good, bad, or indifferent thing to do? I guess I'm just paranoid since I know I'm never parting with this evo and find myself questioning some of my past practices.
