Final Drive Chain Cover
Old Nov 15, 2014 | 06:46 AM
Granpita's Avatar
Granpita
Default Final Drive Chain Cover
Right after I bought my complete and fully stock '84 FXRT, I turned it over to my indie to stop the oil leaks, etc. In doing so, he added a belt primary but didn't reinstall the final drive oil bath cover after replacing the final chain and sprocket. Is there any reason I can't reinstall this cover assembly, even if it won't have oil in it? I'd like to keep the look as original as possible. I've kept the primary chain assembly so that it can be reused to return the bike to full stock configuration. Thank you.
Old Nov 15, 2014 | 07:40 AM
johnjzjz's Avatar
johnjzjz
if he gave you all the bits and pieces if he did not than getting them is impossable
Y did he change the bike to a belt -
Old Nov 15, 2014 | 08:30 AM
92Fatty's Avatar
92Fatty
Pics would help also. As John states make sure you get all parts they removed. Welcome.
Old Nov 15, 2014 | 10:00 AM
Tom84FXST's Avatar
Tom84FXST
More than likely he installed a "regular" rear sprocket...which will not work with the cover...as far as I know no one makes a replacement for that sprocket.
Tizza1013
Shovelhead
17
Jun 7, 2020 01:44 PM
dasweasel
May 27, 2020 07:26 PM
pbsteve
Shovelhead
13
Mar 17, 2012 10:35 PM
eksofttail
Sep 30, 2010 05:09 PM
scottymcdee
May 28, 2008 09:12 AM
