98 FXDL Primary Chain
Old May 27, 2008 | 05:10 PM
scottymcdee's Avatar
scottymcdee
5th Gear
Default 98 FXDL Primary Chain
I replaced the primary chain, tensioner shoe etc about 2 months ago. Put in 1 quart of primary oil. Adjusted the chain to specs. 2 weeks ago the chain was making noise so I pulled the cover and checked, sure enough the chain was loose and there was no oil in the primary. I re-adjusted the chain again, put in another quart of oil. NOW, today I have chain noise again, no oil. Why is the chain loose, where did the oil go??? Doesn't appear to be an extra quart in the tank, bike doesn't leak. When I replaced the chain I noticed the compensator was worn slightly but not that bad. Any comments, suggestions??
Old May 27, 2008 | 08:12 PM
hk_shooter's Avatar
hk_shooter
Default RE: 98 FXDL Primary Chain
Not sure about the continual loosening of the tensioner, but the oil sounds like alien abduction(sorry, I couldn't help it)
Seriously, it does sound pretty weird.
How many miles between the events?
Old May 27, 2008 | 09:52 PM
06dynablack's Avatar
06dynablack
ORIGINAL: scottymcdee
look out for the hd police you only have 6 posts your treading on shakey ground.you might get labeled a troll.
sorry i cant help you with your question unless you have one hell of a leak underside of your primary cover perhaps
Old May 28, 2008 | 05:31 AM
scottymcdee
5th Gear
only 500 miles when thechain loosens,found the drive belt is oil soaked. doesn't drip any oil though, weird situation. once i removed the bags, chrome from the belt drive, there was the oil.....
Old May 28, 2008 | 09:12 AM
hk_shooter's Avatar
hk_shooter
Well, there goes my alien abduction theory.
That still sounds strange, 2 quarts of oil and no drips.
That belt has got to be trashed(and acting remarkably sponge-like)
Sounds like probably a bad seal.
Any noises, like a bearing?
Original primary chain?
How many miles on it?
cajun1957a
Shovelhead
Jun 22, 2014 12:16 AM
SBM
Dec 12, 2008 07:21 AM
site351
Sep 24, 2008 10:59 AM
bugmann78
Jan 27, 2008 03:34 PM
yota
Apr 24, 2007 10:26 AM
