98FXDL Oil Missing?
Old Dec 12, 2008 | 07:21 AM
SBM's Avatar
SBM
1st Gear
Default 98FXDL Oil Missing?
this is strange. I bought this bike with near 70K on the clock, got it running and the primary chain was rattling in the case. tore it down, chain was stretched to the max along with the adjuster worn out. replaced these items, new gaskets, put new oil in the primary. 100 miles down the road, chain starts making noise, oil on the drive belt and rear wheel, (it was oil soaked when I bought it also but primary drain was loose and I thought this was the source of the oil spray) no oil in the primary. Guessing (from reading forums threads) the trans output shaft seal is toast. Question is, I've heard of blocking engine oil/primary oiling with plugs and running seperate oil in just the primary. How do i do this? Thanks!
Bulldog1085
Shovelhead
51
Oct 22, 2019 03:57 PM
Mark Christy
Jan 22, 2019 10:25 AM
skipc
Ironhead
Apr 23, 2011 06:20 AM
mickael moore
Jun 7, 2009 07:47 PM
vetto
Shovelhead
Aug 13, 2008 02:00 PM
