primary oil and chain
Before that year [about 1976 or so] there is an oil transfer valve in the primary that causes some engine oil to mix with the primary oil. This is the reason for using the same in both. Some guys plug this valve. If this has been done then a good alternative would be HD Formula+ for the primary.
Plugging the oil transfer valve is very controversial. Some guys say absolutely do it, others say absolutely do not do it. You can find discussions on most any HD forum. Read and make a choice. I am in the "leave it in there fix it if it is broken" group.
Which oils to choose is also very controversial. The choices i mention here are the ones that i use.
This is the primary oil level screw ...
1.5 pints or until it drips out of this hole with the bike level then wait until it stops dripping.
1 1/2 pint of trans fluid, I and a lot of folks use HD 60wt motor oil, there's obviously other products.
