Knocking S&S evo
Old Dec 7, 2014 | 08:09 PM
clark-kentski's Avatar
clark-kentski
Default Knocking S&S evo
This is driving me nuts,anybody know why this motors knocking?
Old Dec 7, 2014 | 08:15 PM
tmanbuckhunter's Avatar
tmanbuckhunter
Make sure everything is tight?
Old Dec 7, 2014 | 08:20 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Collapsed lifter, bent pushrod, could be any number of things.
Have you opened anything up yet?
Old Dec 7, 2014 | 08:44 PM
clark-kentski
Yes I pulled the lifters and rollers were smooth ,noplay also pushed down on them and couldn't make them collapse ,pushrods are straight.
Old Dec 7, 2014 | 08:51 PM
texashillcountry
Dirt don't hurt
Solid or adjustable pushrods?
Old Dec 7, 2014 | 09:18 PM
clark kentski's Avatar
clark kentski
6th Gear
Adjustable pushrods,i also checked motor mounts,compensator nut.
Old Dec 7, 2014 | 10:03 PM
misfitJason's Avatar
misfitJason
Hiem adjuster on motor mount if it is rubber mounted or air cleaner backing plate. Next guess is the ?
Old Dec 7, 2014 | 10:14 PM
NO PCKL's Avatar
NO PCKL
Really hard to tell from the video. Have you done the screwstick stethoscope thing to find out if it's a mechanical nock, and where it might be coming from? Could it be an exhause leak? Just thinkin' out loud..........
Old Dec 7, 2014 | 10:17 PM
johnjzjz's Avatar
johnjzjz
does it go away when you load the motor going up a hill ????????
Old Dec 7, 2014 | 10:20 PM
clark kentski
6th Gear
My check of motor mount was to loosen the bolt going thru the bottom mount to make sure it was not bound,it was nice and free. The heim adjusters seem tight,dont know how to check.Air cleaner backplate I have had off and reinstalled.My first idea was in the rocker covers and I did have to relieve a few areas that had made contact.
