1990 softail........hitting the start switch does nothing, jumping the solenoid works....im not sure what I should be looking at to fix the problem? does the 30 amp breaker in the back of the bike on the splash guard have anything to do with the starter? with the ignition switch on, I had 0 volts running across the 2 posts...I was sure I should have 12....thinking that's the problem but don't know if that's involved with the starter....
could use some help. thanks
if its the green wire on the solenoid...I have nothing....I took apart the handlebar switch and I have power going to it and out of it when its pressed....
where does it go from there! lol........
wait wait....theres is a little black wire that's zip tied to the 5 prong wire going to the relay.....does that have to go to the ground in order to work?
well...that did nothing
You should have a 5 prong relay of which your bike only uses 4 of them.
The center pin is for dressers.
Did you ever check if that was a ground or if it had voltage on it?
I would check it with a volt meter before I just hooked it up to something.
The relay needs to be grounded...as in the schematics. ( Terminal 85 ).
It could be that the PO ran a fused wire from the battery to pin 30 on your starter relay to fix the dreaded click.
Check to see if that is so and if the fuse is good.
