Didn't have the brake lever installed in this pic... installed it the next day. I removed the forward control on that side completely along with the mount and plugged the holes with chrome plugs. Had to remove the heat shields for all that hooplah.
I didn't make a habit of it! Until you chaps introduced legislation and took the fun out of riding, many of the brands had different ways of doing things, like Indian using a lefthand throttle. They don't make 'em like they used to......
I almost forgot. the first thing the old man drug home was a 1965 Harley (Aermachi) M50. It was a 3 speed with the shifter being the left hand grip. From there it was all 125 Yamahas until the Hodaka craziness set in.
What kind of project is it to remove the internal stuff you're missing from my bike to get you fully switched over?
Do I have to change the inner primary or is there a block off plate or something that goes in there? My bike would look better without the little nub of a mid shifter cover on there.
Have to pull the inner primary. Mine is plugged up but I'm not sure how... sure does have a lot of RTV on it.
I might be up to that. I'd need to swap you for that blank off cover for the outer primary though. I might need to think about this one for a bit, its a few hours of work out there in the cold.
Don't worry about it man... I'm happy with my GP shift set up, and it's going to be a long time before that inner primary comes off again.
