Base gasket weeping
Old Dec 29, 2014 | 07:14 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by WalterM817
If you do replace the gaskets I think you're supposed to replace the head bolts as well. Might want to check that but I've heard they stretch and won't seal well after use. Of course I wouldn't be the first one to have smoke blown up the old kazoo by a mechanic.
If you still deal with that mechanic let us know what else he tells you so that we can tell if more smoke is being blown.
BTW just because you are replacing base gaskets doesn't automatically mean you have to replace the studs/bolts.
Old Dec 29, 2014 | 08:15 AM
Tee&Vee's Avatar
Tee&Vee
On many heads this is 100% true to having to replace the head bolts, cars with aluminum heads anyways. You'll never get a true torque reading from re-using the head bolts. The do in fact stretch with thousands of heat cycles if you start the car twice a day and it is 5 years old. I have not replaced a head gasket on a car since a 1990s Ford Taurus so my experience is admittedly low........
Just what I've heard through the grapevine.
Old Dec 29, 2014 | 08:23 AM
Uncle Larry's Avatar
Uncle Larry
Any "Torque To Yield" bolt should be replaced when servicing ... but that doesn't apply to this application ...
Old Dec 29, 2014 | 08:32 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Good advice from Uncle Larry.
I'll add by saying that the Evo cylinder bases many times need to be machined to establish a precision gasket sealing surface and the primary side of the rear cylinder being the biggest offender.
Here, we accomplish that to the point that the cylinder bore ID, is EXACTLY 90* perpendicular to the cylinder bases once completed.
With a good Cometic gasket set, and torqued to 42 ft/lbs as per them, they stay leak-free.
Scott
Old Dec 29, 2014 | 09:10 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Just some info about torquing and degreeing fasteners.
Many people think that because a fastener is torqued, and then turned a certain amount of degrees, that it is a Torque to Yield part that can only be used once...not true.
A lot of reusable fasteners are installed using this process, because it is the most accurate way of determining actual fastener tension.
The only way to know if the fastener is a Torque to Yield and cannot be re used is by the service manual.
Old Dec 29, 2014 | 09:32 AM
Uncle Larry
It is a generally accepted ( and recommended practice ) to not reuse TTY fasteners. No there may be more information available today ( I'm a retired ASE Master Tech ) I always replaced when initially doing the service rather than finding time to re-do the service although I do respect your advice
Old Dec 29, 2014 | 09:56 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Hope I did not come across as disagreeing with you. Yes, TTY bolts are very limited use parts.
I was just pointing out to any that may not know, that the only way to determine that the fastener is actually a TTY part is by the service manual, not by the process used to torque the fastener.
Old Dec 29, 2014 | 10:03 AM
Uncle Larry
We're all good Dan :>)
Old Dec 29, 2014 | 10:05 AM
Jim Kraft's Avatar
Jim Kraft
I have 47,000 on my EVO with nary a leak and has never been apart. Mine did start to seep one time when I changed to Mobil 1 V twin synthetic oil. I only ran it 1,000 miles and changed it back to Castrol GTX 20-50. It quit seeping right away. I also let it warm up until the rocker boxes are getting warm. If mine was just seeping I would not do anything to it until it started actually leaking a puddle. But, that is just me. If it aint broke don't fixit. Evo's can run 150,000 miles if taken care of without taking them apart.
Old Dec 29, 2014 | 12:56 PM
falconbrother's Avatar
falconbrother
If the base gaskets are weeping then it's easy to replace them. If you have a good set of tools THAT YOU KNOW HOW TO USE and a good torque wrench it's a two day job. Pull, the tank, rocker boxes, rockers, push rods (remember how they go back), heads, and the slide the cylinders up till you see the wrist pin circlips. Pull one side, slide the pin out till the piston comes off of the rod. Inspect the inside of the cylinders for cross hatching. Make sure the pistons and valves look good. Shove clean rags down in the spigot holes to keep junk out.
The hardest part is scraping gaskets without damaging the aluminum cases and cylinders. Soak the female head bolts in motor oil. Get some Genuine James gaskets and reassemble using all new O-rings and gaskets. Use new wrist pin circlips. Torque the head bolts exactly as the book says. Instal the push-rod tubes in the order they came out. You're back in business.
I have a buddy with 260,000 miles on his old EVO, FLH. He has done this job a half dozen times since 1986. He has never had the cylinders or heads reworked and is still one the original pistons and rings. His bike is stage one, stock cams, etc.. I did this job on my old Heritage two years ago it took me about 16 hours total. But, I took my time and was super careful scraping gaskets.
