2000 up Dyna Front Wheel To a 99 down Fatboy
Old Jan 3, 2015 | 04:21 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Default 2000 up Dyna Front Wheel To a 99 down Fatboy
Has any one ever tried to fit a 2000-06 Dyna FXD Super glide or FXDWG, front rim 19x2.5 w/ 3/4" axles and sealed bearings to a 99 and earlier FL fatboy? HD pn#43538-09. according to my loco this rim uses a 3/4" axle w/sealed bearings and I'm thinking if the axles are the same diameter wouldn't i be able to fit it the rims including the rotors? It would help if some one could measure the distance between the forks (at the axle mounts) and measure the width of the hub. I'm also looking to do the same with the rear. Thanx...
Old Jan 3, 2015 | 04:32 PM
SeaZund's Avatar
SeaZund
you actually want somebody here to pull their wheel off, just to measure something for you?
Old Jan 3, 2015 | 04:36 PM
Rhino-1's Avatar
Rhino-1
It will bolt right up. Just use your spacers.
Old Jan 3, 2015 | 06:23 PM
98hotrodfatboy
Default No
Dude Really? I'm not looking for someone to rip apart their ride......... some have rims laying around and could take a minute to see that"s all.
Rhino, do you think the rotor will line up as well? Thanx..
Old Jan 3, 2015 | 09:32 PM
Rhino-1's Avatar
Rhino-1
When I did the research for a buddies bike, we found the spacing the same.
Old Jan 4, 2015 | 03:08 AM
98hotrodfatboy
Default very good,,
Thanx, I'm gonna order the rims, floating rotors and axle kits Monday from loco. 19x2.5 front and the 16x3.5 rear. All for $1380.00.I'll post when done... thanx again.
emory70
Wheels/Tires
Dec 24, 2014 10:48 AM
Boomer8484
Aug 14, 2011 11:47 PM
Oldfart666
Wheels/Tires
Nov 23, 2010 04:17 PM
MsBobber
Apr 8, 2008 07:55 PM
GeorgeJ
Aug 16, 2006 08:43 PM
