89 tour glide headlight upgrades...
Old Jul 31, 2015 | 03:58 PM
hoakken's Avatar
hoakken
Changing bulbs is good but before you do check available volts at the light when in operation(engine running fast idle, lights on high beam, radio on ) On both FLTs I have owned (current one is 89 FLTC) volt drop was bad, 1 to 1.5v, divided about equally across the faring to frame connector and the weak (and unavailable) ignition switch. Replace connector with current automotive type weather proof connectors like on new cars and run 10 gauge breaker protected wire from battery to instrument cluster to power relays for lighting position or ignition position and use existing switch only to control relays( only one relay needed if you have lights on full time) that will now supply plenty of current to all devices. Made a huge difference in light operation with none of modification visible without disassembly of the side cover. At the same time I recommend the second relay fix for the start circuit as you already have the cover off and will never have to experience the dreaded click.
Old Mar 26, 2016 | 11:49 PM
ddooley81's Avatar
ddooley81
Stage I
Originally Posted by fireman_033
It would prolly be a good idea to do away with that tour glide fairing all together and put an electra glide fairing on your bike since it has a bigger headlight.... I happen to know where you could send your fairing and get an Electra glide fairing sent back to you...
What about replacing a Tour Glide fairing with a Road Glide fairing? What would that take to do?
red deuce
Dec 6, 2018 01:33 AM
QHayes
Jul 6, 2017 04:15 AM
Groucho1
Jun 21, 2013 11:34 AM
Scudda
EVO
Jan 28, 2013 08:52 PM
Fattire_Biker
Jan 2, 2011 08:23 AM
