Pressure wash
Old Feb 12, 2015 | 09:13 AM
Big Dave's Avatar
Big Dave
Default Pressure wash
98 RK ---- I want to tackle the heavey grime on the underside , can the bike handle car wash style pressure wand , old Shovel didn't like it so I was wondering with wet primary where is the vent? Anything else to watch for ?
Thanks
Dave
Old Feb 12, 2015 | 09:43 AM
flhchaz's Avatar
flhchaz
I would just use s100 and a scrub brush, it may take a couple times, but make sure the bike is cold. the s100 will loosen the gunk and the pressure from a regular garden hose will be enough to rinse it off.
Old Feb 12, 2015 | 09:53 AM
Big Dave's Avatar
Big Dave
What is s100 , is it like engine gunk ? i guess any degrease'r would work
I was thinking the car wand as its hot water
Dave
Old Feb 12, 2015 | 09:54 AM
Imold's Avatar
Imold
Pressure wands - force water and grit past wheel bearing seals, force water past spoke ends into rims (not much, but enough to rust), peel paint from paint cracks and chips, and can screw up electrics. I've seen too much damage from high pressure water (on cars and airplanes, too) to ever consider using one, on any part of the bike. Lot of guys do, though, and sometimes they get away with it...
Dave
A lot of standard degreasers leave a film with just a water wash, bike will feel oily - and dirt will stick to it. You'd have to wash it good with soap.
Old Feb 12, 2015 | 10:14 AM
flhchaz's Avatar
flhchaz
S100 is a total cycle cleaner. it is available at all bike shops.
Old Feb 12, 2015 | 01:56 PM
Beemervet's Avatar
Beemervet
Thanks
Dave
no no no never
Old Feb 12, 2015 | 02:56 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If you need cleaning tips you really need to talk to Traildog!!!!!
He is the cleaning Guru of the EVO section!
Old Feb 12, 2015 | 03:32 PM
Ron750's Avatar
Ron750
I don't like S100. Too strong. I
Use some Simple Green diluted in a bucket of water, a rag, and some elbow grease. Use 10% To %100 depending how bad it is.
Old Feb 12, 2015 | 04:39 PM
Owtlaw's Avatar
Owtlaw
Simple Green here as well. It's all we use at the shop too.
Old Feb 12, 2015 | 07:50 PM
MIKE93SVT's Avatar
MIKE93SVT
Nothing wrong with a pressure washer. I tend to buy bikes that are horribly covered in gunk. Simply cover the important part with plastic bags like carb, and battery area. Spray away and don't point it at the vulnerable spots like base of push rod tubes, iggy cover, etc
Mike
