Ignition module question
Old Mar 4, 2015 | 07:38 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Spanners39
Traildog isn't real either....which should come as a relief to ya....
I'm kinda torn about that one.
On one hand it restores my faith that no man has taste that bad on the other hand I'm gonna miss the cakes!!!!!!!!!!!!
Old Mar 4, 2015 | 08:53 AM
Dr.Hess's Avatar
Dr.Hess
Next thing you'll be telling us is that Sea Foam isn't magic.
Old Mar 4, 2015 | 10:07 AM
traildog's Avatar
traildog
Scuse me? Not real? Where the flock did you get that sensor? You, you, ĄŹ\] Ł{{Ž||^Ą~Ś\; §<&trade;÷;<§^~ĄĄŚ|÷;`{<} ˘[
Old Mar 4, 2015 | 10:08 AM
traildog's Avatar
traildog
BLASTPHEMY, pure BLASTPHEMY!
Old Mar 6, 2015 | 03:01 AM
Spanners39's Avatar
Spanners39
What sensor????
Old Mar 6, 2015 | 03:02 AM
Spanners39's Avatar
Spanners39
That part is true enough....
Old Mar 6, 2015 | 04:19 AM
traildog's Avatar
traildog
Ban him........
Old Mar 7, 2015 | 10:30 AM
pococj's Avatar
pococj
Back on topic, LOL! (he says as he sits here eating the ears off'n a choco Easter bunny)
Older Evo Sloptails have the module mounted on the underside of the oil bag, not exactly an easy place to get to, and not exactly the coolest place, either. When I stripped my '87 to its bones I found the P/O had installed an SE module. Since I was replacing the horseshoe bag with a round one I sorta lost the easy mounting location. Plus the stock modules had about eleventy-seven wires, which just seems like too many. I went with a cone module, a Dyna S DS6-1. Only 2 wires from the cone to the coil. Used a high quality mechanical advance unit, and all has been trouble-free for several years.
FWIW, other electrical upgrades include a later alternator with a regulator that doesn't shunt the excess output to ground, a Spyke SuperTorque starter, Accel solenoid, and ThrottleX battery. Did away with the starter relay completely as my switch box (lights, horn, turns, etc.) uses a heavy duty MilSpec SPST spring return toggle switch to directly power the solenoid.
The switch box itself was used to power the recognition lights on a WW2 Navy aircraft. That box sat in my Dad's footlocker for 30+ years until he mounted it on my first chop, a '72 XLCH. Since then it has migrated from the '72 to a '78 FLH, and now to the '87 FLST.
Old Mar 7, 2015 | 10:36 AM
Prot's Avatar
Prot
There are many things you are unaware of my friend (like there ain't no Santa Clause)....but we don't want to rock your world too much....
And that is precisely why I don't bring you presents, except of course for the occasional tranny.
Should I post a picture of my belly and beard to make you believe?
Old Mar 7, 2015 | 02:29 PM
Beemervet's Avatar
Beemervet
Romance, romance
Get a room.
