Starter installed, lathe time required to establish proper clearance on the pinion gear. Sourced heim-joint for shift linkage, used a button head stainless bolt for clearance between shift and front cylinder. Sizing a stainless button head to mount speedo sensor to transmission... all the little things that go into fitting the puzzle together.
