No kill switch
Old Mar 21, 2015 | 11:19 AM
glidein wide's Avatar
glidein wide
Default No kill switch
1986FXWG ,What would cause kill switch to only prevent starting but not kill running?
Old Mar 21, 2015 | 01:21 PM
Racepres's Avatar
Racepres
Bad switch or pinched wire...You gotta take the ight side control off and Look now. [Note the white wire is "out" from the kill switch.]
Old Mar 21, 2015 | 02:07 PM
Dr.Hess's Avatar
Dr.Hess
I'm going with "creative wiring by a DPO."
Old Mar 21, 2015 | 02:16 PM
Dr.Hess's Avatar
Dr.Hess
Do you have an aftermarket ignition? I bet someone wired it in direct to the ignition switch. Pinched wire won't affect anything. Measure the voltage on the + side of your coil with the ignition on, kill switch on. Should be +12V. With the ignition on, kill switch off, it should be 0. Start tracing back from the coil +. There should be 2 white wires, one of which should eventually makes it up to the kill switch, through a connection. The other white wire on the + goes to the ignition module.
Old Mar 21, 2015 | 02:32 PM
Racepres's Avatar
Racepres
Originally Posted by Dr.Hess
Pinched wire won't affect anything. .
OK...Pinced to the point of shorted to something else...Probably Not Ground in this case..But pinched to ground [handlebar] is not at all uncommon on H-D controls....Folks don't pay enough attention when re-assembling.
Edit; Never heard of anybody wiring an aftermarket ignition directly to the keyswitch...But...There is one born every minute, and on re-read it sure sounds like what has been done...Instructions be Damned!
Old Mar 21, 2015 | 03:56 PM
glidein wide
I will add this, that is how the switch worked when I bought the bike from a "hacker". I replaced the handle bars with dimple in them and took the extra step to machine them as to run wires inside. Checked for loose connection, pinched wires, all was well.I shortened the harness because I removed 16"apes. All connections are great heat shrink and all that. HOWEVER my forgettfullnes sucks, after painting and reassembling the bike is when I said F @#% , I wanted to trace that white wire everywhere because that has to be the culprit. The switch should be good because it does block starting when it's on. I know, pull the tank and seat and follow it.
Old Mar 21, 2015 | 04:28 PM
Racepres's Avatar
Racepres
In don't think pulling tank and seat to start...Start at the coil..
One side 12v the other side trigger from ignition module...If two white wires are there...One should go to ignition module, and one to KillSwitch. Only.
BTW..If there is a Pink wire...that is tach, attached with trigger
Old Mar 21, 2015 | 06:32 PM
glidein wide
Thanks, will scope that out first.
Old Mar 21, 2015 | 07:07 PM
Harleycruiser's Avatar
Harleycruiser
Yea what the Dr said, po has wired the ignition straight to the ignition switch left the start circuit on the kill switch.
Old Mar 22, 2015 | 07:38 AM
glidein wide
Ok,there are two wires, a blue and white wire coming out of tube,blue top,white on bottom and another white wire by itself also going to the bottom terminal. Ing on ,kill switch in "run" position and "off"position there is12volts to both terminals.three wires total, no pink .
