No kill switch
Old Mar 22, 2015 | 09:49 AM
glidein wide's Avatar
glidein wide
With bike running I pulled white from#3 and died,pushed white down in the empty#4 hole with needle nose and started right up ,flipped kill to off and it died... Waahooo!!! Now I need to get that piece out so I can plug it in or connect the two.
Old Mar 22, 2015 | 09:59 AM
Dr.Hess's Avatar
Dr.Hess
Good job. Proper diagnostics is 70% of wrenchin'.
Old Mar 22, 2015 | 10:14 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The broken piece inside is probably why the PO re routed the connection.
You could bypass that connector altogether by simply splicing the wires together and protect with shrink wrap.
It doesn`t appear there is any electrical reason for the wire to go through that connector, it does not power anything else.
If you do this, draw it into the wiring diagram of your service manual to indicate the change.
Old Mar 22, 2015 | 04:20 PM
glidein wide
All set, soldered white wires together and heat shrink tube,could not get that piece out of there even with tweezers but that's fine. Thanks guys
BaggerBill103
Sep 4, 2019 08:11 AM
steve. m
Apr 11, 2016 08:23 PM
streetleon
Jun 21, 2012 02:45 PM
781/2fxs
May 13, 2009 11:24 PM
skullguy
May 6, 2009 02:59 PM
