Another Jets question
Old Apr 13, 2015 | 08:25 AM
falconbrother's Avatar
falconbrother
If you have to choose, in an imperfect world, be a shade rich over a shade lean.
Here's some useful info:
http://www.nightrider.com/biketech/hd_cv_mods.htm
http://www.harley-performance.com/ha...r-jetting.html
Old Apr 13, 2015 | 10:10 AM
Schex's Avatar
Schex
Bennie,,,,Bennie,,,,Bennie and the Jets
Old Apr 13, 2015 | 06:33 PM
hubcap's Avatar
hubcap
Originally Posted by Hasher
The CV doesn't have an "intermediate" jet. It has a low speed, which is the one you discussed and stock is, as stated #42. Change it to a #45 and see how it runs. Also, remove the plug behind the bowel, there's an idle mixture screw under it. LIGHTLY seat it then turn it out 2 1/2-3 turns.
Check the hight speed jet, it should be 170 to start. Run the bike and check the plugs. Black, too rich, needs a smaller jet, white, too lean, needs a bidder one. The plugs should be brownies grayish.
Thanks for the info, stopped on my way home and got a #44. I will run with that for a little and check the plugs.
Old Apr 13, 2015 | 06:35 PM
hubcap's Avatar
hubcap
Originally Posted by Tee⋁13912674
Nice job on the bike! That "hubcap", pun intended, looked doofussy on your bike.
Thanks Yeah I couldn't get those things off fast enough.
Old Apr 13, 2015 | 07:55 PM
hubcap's Avatar
hubcap
Well....I just pulled the jets and they are #45 and a #175. I guess I should've pulled them before
Old Apr 14, 2015 | 12:34 PM
92Fatty's Avatar
92Fatty
Well now days you can return anything. At least you know what you have now. You may want to inspect the needle and see what one you have. It may have washers on it also. Clean it up. Check float level and put it back together.
Edit: Also pop the cap off the idle mixture screw if it isn't already gone. It sounds as if someones been there before.
Old Apr 14, 2015 | 04:14 PM
Hasher's Avatar
Hasher
You have the right jets, although the 175 may be a little fat but it's not causing the problem you describe. How many turns out is the idle mixture screw? The #45 won't matter if the screw is too far in.
Also, check the accelerator pump.
Old Apr 14, 2015 | 08:04 PM
hubcap's Avatar
hubcap
Put a 48 in there. I'll ride around for a couple days then check the plugs. I let it warm up and rode it around the neighborhood and it didnt stumble or cough like it did before. Thanks for all the help guys, I appreciate it.
theonlychrisj
Jan 11, 2017 09:54 PM
wyotana
Jul 11, 2014 12:43 PM
95yj
EVO
Jun 9, 2011 03:26 AM
oldyeller
Dec 24, 2009 03:00 PM
lowriderrob
Exhaust System Topics
Feb 7, 2009 07:04 AM
