Clutch hub help
Old Apr 24, 2007 | 02:35 PM
Eagle_SC's Avatar
Eagle_SC
1st Gear
Default Clutch hub help
Tearing down my 1989 FXRS-SP, trying to pull the clutch hub. I put a puller on it and it dosen't want to budge, being Aluminumin I don't want to pull to hard. Was woundering if anyone has any tricks to help with getting this hub off.
I have tried heat, but again I'm trying not to damage the hub, the rebuild is going to be expensive enough.
Also looking for a good place to get new tin (fenders, gas tank, and oil tank).
Thanks
Old Apr 25, 2007 | 12:21 PM
89FLHT's Avatar
89FLHT
Default RE: Clutch hub help
On my '89 I use a thick disk with holes in it to let all the clutch bolts slide thru and then tighten them down on the disk and the clutch hub.. The center of the disk has a long bolt that I tighten against the tranny shaft and the clutch hub "pops" off (It's on pretty tight). It is on there pretty tight and the tranny shaft has a key way in it as does the clutch hub. When you go to put it back together make damn sure the woodruff key sits perfrctly in the hub abd the shaft or it will crack the hub when you tighten it. I always use green loctite to set the key in the shaft and ensure that it does not move while installing the clutch hub.
Old Apr 25, 2007 | 12:44 PM
89FLHT's Avatar
89FLHT
Fenders and Tank available from J&P or any other big aftermarket company. Oil tank will be tough, that'll be ebay, craigs list, searching independent shops etc...
Old Apr 25, 2007 | 05:46 PM
LowriderFXRS's Avatar
LowriderFXRS
Make sure you have the inner snap ring removed.
nicoleelyssa
Jun 7, 2021 09:36 AM
Saun
Shovelhead
22
Sep 23, 2017 10:38 AM
djaudette
Apr 18, 2016 08:16 AM
DannyNY
Aug 9, 2011 09:02 PM
mikeb7
Feb 22, 2009 09:33 PM
