Another oil question
Old Apr 25, 2015 | 05:38 AM
superwoody2's Avatar
superwoody2
Default Another oil question
Just picked up a '98 Springer w/ 36,000 on her. Bike's in perfect shape & the guy was sooooooooooo proud of showing & telling me he used Mobil ! synthetic in the engine. Now, there are no weeps, no smoke, bike runs good. I've run dino in every evo I've owned. Can/should I switch to dino at this point or is the bike set in her ways by now?
Old Apr 25, 2015 | 06:12 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You can switch if you want it doesn't matter.
Old Apr 25, 2015 | 07:46 AM
glidein wide's Avatar
glidein wide
If he was using **** oil I would say switch, conduct an experiment and keep using mobile just keep in mind that with those miles it will start to leak eventually regardless.
Old Apr 25, 2015 | 09:37 AM
br549A1's Avatar
br549A1
If every Evo leaks with synthetic and it's not recommended to be used in Evos I would tend to believe the seller is telling you a bullshit story because everyone even non gear heads know the name Mobil 1 synthetic. If I was you I'd change the oil to whatever Evo compatible oil I was using in the past. I think you'll find leaks as soon as you change it and use synthetic, people lie especially when they want to take your money.
Ape_Hanger's Avatar
Ape_Hanger
I would switch.
Old Apr 25, 2015 | 09:59 AM
RidemyEVO's Avatar
RidemyEVO
I tried synthetic once.
ShadowforNow
Nov 17, 2018 02:16 PM
roadhog96
EVO
36
Apr 20, 2013 07:20 AM
WVICEMAN
Apr 5, 2007 06:59 PM
MT
Oil Archive (no new posts)
Mar 15, 2007 06:32 PM
