ohm value ets 98 flhtcui
Old May 4, 2015 | 03:47 PM
ultrajas98's Avatar
ultrajas98
4th Gear
Default ohm value ets 98 flhtcui
can anyone tell me what the engine temp sensor should ohm out at around 75 degree F..?? HAVE 14 code, idle hi-lo,sputters under load,sounds like ets but want to be sure b-4 spending $100.00...Thanks
Old May 4, 2015 | 04:00 PM
Beemervet's Avatar
Beemervet
Common failure, I did two in less than 100K.
Old May 4, 2015 | 04:12 PM
flhchaz's Avatar
flhchaz
No idea, If your ecm is in good shape, an Indy with the appropriate scanner can tell you. My ecm (also a 1998 flhtcui) would not register on the Indy's scanner, that's why is has an S&S super e now.
Old May 4, 2015 | 04:47 PM
Beemervet's Avatar
Beemervet
No scanner necessary. He has already pulled the codes, although the ETS does not always through a code. Go ahead and spend the $100. Consider it the EFI tax.
Old May 5, 2015 | 12:05 PM
ultrajas98's Avatar
ultrajas98
4th Gear
Thanks to all for your replys..gonna get a new ets..will update everyone on results
Old May 6, 2015 | 01:02 PM
ultrajas98's Avatar
ultrajas98
4th Gear
Default ETS 98 flhtcui
looks like,sounds like,it is....replaced ETS today,up & runnin YEAH!! Thanks to all for your replys. After workin on appliances for last 30 yrs have come not to believe what control modules tell you...interestingly I ohmed out new ETS at 2.0 bad one read 2.1,probly goes haywire after heating up,but learned ya cant try to be too smart with this -rap,gotta go with what ya see..Thanks again...in the wind!!
WoodButcher66
2014-2024 Touring Models
May 31, 2021 06:08 PM
Dcampri
May 2, 2019 11:11 PM
neilwhittal
Engine Mechanical Topics
Aug 7, 2017 12:26 PM
lowglidin
14
Jul 5, 2017 06:10 PM
rtbassmaster
Exhaust System Topics
May 9, 2013 07:14 PM
