Front master cylinder removal 85 Electra glide
Old May 6, 2015 | 12:19 PM
section8joe's Avatar
section8joe
Default Front master cylinder removal 85 Electra glide
I'm trying it clean/rebuild a buddies front mc. It's an 85 Electra glide with duals. Here's where I'm at... Lever if off. Plunger with the brake switch actuator if off,cylinder with oring is also off. There is a blue plastic or rubber piece that needs to be removed but I can't figure out how to get it out. What needs to happen to remove it? I didn't want to pick at it with a pick so I stopped for the night and I figured would create a post to help me out. I'm hoping to be able to simply clean all the parts and reuse then.
Old May 6, 2015 | 12:26 PM
bluharley's Avatar
bluharley
Push it out from the other side with something dull, if my memory serves me right.....which could be in question.
Old May 6, 2015 | 12:32 PM
section8joe
What purpose does that plastic piece serve? Does it simply hold the spring in place?
Old May 6, 2015 | 12:40 PM
bluharley's Avatar
bluharley
Helps keep your fluid where it belongs. Keep your spring in place, protect the plunger. Not sure of the exact purpose, but if it isn't in there correctly, you will have fluid coming out and dumping on your leg. Trust me.
matt_m_72
Aug 9, 2015 08:39 AM
moerule s
EVO
Jun 28, 2015 08:26 AM
harley3515
Jan 4, 2015 09:16 PM
tom lipke
Jan 7, 2012 12:04 PM
