More EVO problems....
Took a picture of the plugs ( Front is the lighter one, rear is the one that looks like its extra rich).
Also took a video of the bikes symptoms.
From what I read online so far, it sounds like a vacuum leak somewhere is causing the front cylinder to run lean (previous owner may have adjusted to run richer to compensate which is why the rear is different... does that sound right?) I dont know how the cylinders could be burning differently.
I sprayed brake clean around every joint on the carb, intake Y, to the heads etc.. no change in Idle while running and spraying...
Pulling my teeth out, i cleaned the carb twice, put new packing kit in the A/F screw, adjust it accordingly, made sure the pilot (45) was clean and its passage too, everything seems to work in the carb its just that 1/4 throttle hesitation (which I know is pilot circuit/A-F screw)
https://www.youtube.com/watch?v=rI4I...ature=youtu.be
I sincerely like to prove everything, starting with the stupid **** first. Fill tank, close petcock remove gas supply from carb and get a bottle to catch gasoline. Did it pour out rapidly? Is it as clean as can be, debris?
I have more time than money.
Good luck,
Tom
Stock ignition so thats a dual fire, ill try what you suggested.
I have a VOES off my sportster that was removed, Ill try wiring that in and see what happens. It just doesnt seem right because its only when i hold it like 1/4 throttle. It wouldnt run fine 1/2 and better if it didnt work.
Im begining to think maybe timing, or the something to do with that sensor plate. Mine appears fine but who knows... Running out of options here
EDIT, i forgot to mention i tried my friends stock ignition off his 96 EVO that runs just fine, no change at all
