turn Signals Lit But Not Blinking..
Old Jun 1, 2015 | 08:02 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by hyrax222
The two grounds at the seat are good.
I don't know where the ground from the speedo and tach meet up with the ground from the TSM. Probably under the tanks...
Everything is working (grounded) but the turn signals.
How can I "Ohm Out" the wire if it is broken or disconnected between the two ends?
Ohming it out will tell you if it is broken in the middle of the room.
Granted that is kinda hard but I'll ask you a counter question.
How will you replace a wire in a loom that is broken inside the loom?
When I said ohm it out I was figuring the problem would be at the connection to the frame.
Old Jun 1, 2015 | 10:30 PM
hyrax222's Avatar
hyrax222
Originally Posted by perki48
did you check your "flasher"?
I didn't know I had a flasher. I assumed the Turn Signal Module did that. I see no flasher on the bike or the schematic.
Where is it?
Old Jun 2, 2015 | 04:42 AM
Harleycruiser's Avatar
Harleycruiser
Where is it?
You don't have a flasher, just tsm.
Old Jun 2, 2015 | 11:39 AM
perki48's Avatar
perki48
My mistake then, I thought I replaced one on my 88' FLHTC but could just be bad memory. Thanks
Old Jun 2, 2015 | 11:51 AM
Harleycruiser
Np
The 88 flh had a flasher and a turn signal canceler up until about 92 or so the hd went with the tsm.
Old Jun 2, 2015 | 11:54 AM
perki48's Avatar
perki48
Thanks again, good to know memory is not completely gone.
Mccula
Electrical/Lighting/Alarm
Apr 30, 2025 04:21 PM
19jake91
Jan 3, 2018 04:00 AM
Good_Apollo
Oct 10, 2013 04:42 PM
bucket13
Aug 20, 2012 08:36 PM
imboden
Aug 24, 2006 11:32 PM
