Anybody wire in turn signals?
Old Aug 24, 2006 | 03:02 AM
imboden's Avatar
imboden
Default Anybody wire in turn signals?
I bought these signals off of ebay, and I'm wonderin which wire is which. there are three....black/blue/purple with a black stripe...
I wanna wire them into my wifes 79 FXS, but I don't know which wire is hot and which is ground.....and why the third wire?
sorry in advance for the stupid questions
Old Aug 24, 2006 | 11:48 AM
twowheelsforever's Avatar
twowheelsforever
Default RE: Anybody wire in turn signals?
Black should be the ground wire. There are two other wires, since one of them should be the running light, and one of them should be the brighter turn signal. If you want to see which is which, just connect the black wire to the negative battery post, and then alternate the other two wires on the positive post to see which is brighter (you should wire the brighter one in as your turn signal).
I hope that helps.
Old Aug 24, 2006 | 11:53 AM
Skip's Avatar
Skip
Black is the ground, purple is the hot lead for turn signal. Blue is the running light. If you don't want to use it, just cut it short and tape it over. If it it fits, you can push it back into the light housing before you tape it off.
Old Aug 24, 2006 | 06:11 PM
imboden's Avatar
imboden
thanks so much for the replys. so I bought a meter at napa and I've been testing things right off of the battery with some wires. this is what has happened so far:
ok edit...just deleted all that crap. I've got it figured so when I hook everything up, they turn signals just FLASH. Then when I push the button they turn OFF and the flasher makes a fast click noise that dosn't stop. What have I done wrong?
Old Aug 24, 2006 | 08:04 PM
Skip's Avatar
Skip
Couple of questions -
1. Are these stock turn signal fixtures?
2. Are they using 1157 bulbs or are they LED?
3. When the lights are flashing, are all 4 flashing?
Old Aug 24, 2006 | 11:32 PM
imboden's Avatar
imboden
yup, stock HD bullet lights...1157 bulbs, none are burned out, and when I hook em up yup they all flash. unless of course I only hook up one side or somethin
white01ss
May 8, 2012 09:59 PM
broski24
Mar 16, 2012 02:55 PM
j88j
Nov 16, 2011 06:28 AM
ambientgravy
Mar 27, 2009 02:29 AM
anubisss
Oct 31, 2008 10:52 AM
