Four Speed Trans
Old Jun 12, 2015 | 08:09 AM
Houstons4's Avatar
Houstons4
6th Gear
Originally Posted by pjb
Are you sure the fluid leaking is from the transmission, and not motor oil?
It could be puking oil from the breather, a common but relatively harmless problem.
Where is your breather hose routed to?
Yes, breather tube is right side of bike (non-drive side). It's definitely tranny, when I say puking I could say pouring, only while leaning on the jiffy stand though. When upright on my lift is barely drips. Oil level and primary level have not changed.
Old Jun 12, 2015 | 08:13 AM
pjb's Avatar
pjb
The 4 speeds are know to leak. I just bought a mainshaft spacer with an o-ring machined in it ebay. The guy that makes them has some videos on youtube.
google harley 4 speed leak fix and you should find it.
I bought it for my shovelhead, but haven't installed it yet.
Old Jun 12, 2015 | 08:21 AM
Houstons4's Avatar
Houstons4
6th Gear
Yep that's the route I'm going. I'm needing information on the OD of the mainshaft, what other seals, gaskets I may run into that I should replace once I have things opened up?
Old Jun 12, 2015 | 09:22 AM
Dr.Hess's Avatar
Dr.Hess
It's a fairly straight forward job swapping out the main shaft seals. Pull the outer primary, clutch (you'll need a clutch puller tool for that), inner primary, drill a hole in the old big seal, screw a dent puller in, pull the seal out, dig out the little inner seal, put it back together.
I had a sprocket nut that had a seal built into it as well for extra measure, back in Shovelhead Daze.
Old Jun 12, 2015 | 09:34 AM
14GuineaPig's Avatar
14GuineaPig
Originally Posted by Houstons4
Also upon further VIN decoding I can add some infor to this conversation:
--1HD1BH tells me it a Heavyweight basic Softail manufactured in the US.
--L tells me it's a 1340 EVO
--19 is confusing but the 1 seems to indicate it's a normal introduction year domestic (what's the 9?).
F indicates she's is a 1985
Y = York, PA
Should also note the VIN decoder on this site could not find anything (what's that 9 after the introduction year number?
The 17 digit VIN has a number that was know as a "Check Digit". It's used to validate the VIN some how. Maybe the "9" is the check digit in your YIN?
Old Jun 12, 2015 | 09:55 AM
Uncle G.'s Avatar
Uncle G.
First year Softails were 4 speed, like yours, but they weren't offered in "Heritage" trim until '86. Yours was modified to "Heritage Softail" configuration after it was built. I see lots of aftermarket parts in that conversion.
Nice looking ride, by the way.
Old Jun 12, 2015 | 01:00 PM
Houstons4's Avatar
Houstons4
6th Gear
Not that I'm looking for this ride to be all original, but what aftermarket conversions do you notice?
Old Jun 12, 2015 | 01:18 PM
Dr.Hess's Avatar
Dr.Hess
Pipes, grips, controls. Not sure about those mirrors. Ignition cover, probably the chrome nose cone. Those handlebars look chrome and not stainless, so those too if that's the case.
Old Jun 12, 2015 | 05:57 PM
Tom84FXST's Avatar
Tom84FXST
The problem is the seal is rarely the problem...just replacing the seal is a short term fix. The brass bushing on the mainshaft is almost certainly worn...and if you don't replace it...any "fix" from a new seal will be short lived.
http://shovelhead.us/pics/sheets/leakingtranny.pdf
Old Jun 12, 2015 | 10:26 PM
Scootertrash60's Avatar
Scootertrash60
On my 85 low Rider there is a vent hole in the rotary top of the tranny. Very small. Make sure you clean it out when you do any work to the tranny. Paper clip works well. I'll try to get out tomorrow and get the location of the hole for you.
JackKnife5
General Topics/Tech Tips
Jul 10, 2018 07:28 PM
BombshellZ
Aug 30, 2016 08:30 AM
Wishbone68
Jun 30, 2014 04:40 PM
fogey47
Apr 20, 2013 05:23 PM
duluth
May 6, 2011 02:10 PM
