I am now a true believer!!!!!!!
Old Jun 30, 2015 | 08:39 PM
92Fatty's Avatar
92Fatty
I thought I had a new bike after I did mine also. Rides great!!
Old Jun 30, 2015 | 09:39 PM
booze hound's Avatar
booze hound
Did this in the Dyna about a month ago.....easy swap and a big difference. Glad I did this mod!
Old Jun 30, 2015 | 10:26 PM
Maxdog2's Avatar
Maxdog2
Installed the front springs over the winter and rear shocks last weekend, great ride and improved handling. Have not riden the new bikes and hear they handle great, but cannot not imagine how it could be better. Also installed the Progressive tourlink and the Glide Pro swing arm bushsing and motor mount.
Old Jul 1, 2015 | 03:46 PM
cromagnon's Avatar
cromagnon
Originally Posted by texashillcountry
In the middle of changing all the front end parts I needed to so that I can put on dual disk brakes I decided to put some Progressive fork springs in.
WOW what a difference!!!!!
Now I see what everybody has been talking about!!!
The ride is so much better I almost can't believe it!!!
Did you do it yourself and if you did, would you describe it as being difficult? The first time for anything goes very slow.
Old Jul 1, 2015 | 04:11 PM
0maha's Avatar
0maha
On my FXR, there wasn't much to it.
Remove the fork nuts on the top (necessitates loosening the upper triple-tree pinch bolts), pull out the old spring, put in the new spring and spacer, replace fork nut, re-tighten triple-tree bolt.
I bought a fork nut socket (
like this one on Amazon like this one on Amazon
), which made replacing the fork nuts a lot easier. Without the socket, getting them started while pressing down against the spring is a chore. With them, it was easy enough.
Old Jul 1, 2015 | 04:19 PM
juiced03's Avatar
juiced03
I did my 93 FXLR and the results were good. Raise front end. Carefully remove fork caps. Remove drain screws and left drain overnight. Added Belray 10w fork oil. Dropped in new springs and pvc spacers. They weren't as long as the old ones so putting caps back on was easy.
Old Jul 1, 2015 | 05:31 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Yes I did it myself.
I was real easy (once I got the right tools for the job).
The hardest part was loosening the pinch bolts which are hidden on the Heritage.
Old Jul 1, 2015 | 07:31 PM
glidein wide's Avatar
glidein wide
Lightbulb
So check this out.. thanks to this thread, I decided to poke around and look at what's involved in redoing my forks... wow, only one pinch bolt. So lets remove it and see if the threads are ok in the empty hole, what ? It's broken inside, out comes the drill and easy out,not gonna happen until I shoot it with pb-BLASTER !!!! Out she came... So , do you think it was the po that snapped it or could this happen from riding, potholes, ect ?
Off to Napa in the AM for new bolts.
This could explain some strange moments I've had riding.lol
Old Jul 1, 2015 | 07:37 PM
Ape_Hanger's Avatar
Ape_Hanger
I did new Progressive heavy duty fork springs and new 412's in the rear over the winter. Everyone said I would hate the heavy duty springs and shocks but I dig it. No more brake dive and the bike has a much more solid feeling under hard cornering.
Old Jul 1, 2015 | 10:38 PM
Beemervet's Avatar
Beemervet
No reason for it to happen while riding.
