I am now a true believer!!!!!!!
Old Jul 3, 2015 | 10:03 AM
  #31
Lucky Luke's Avatar
Lucky Luke
Originally Posted by texashillcountry
I really don't see how it could without changing more than just the springs.
If part of the progressive spring was softer than standard, I suppose it would slump a bit more.
I've never used progressive ones, replacement straight rate springs are another alternative.
Old Jul 3, 2015 | 10:09 AM
  #32
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Progressive springs definitely are not softer than stock ones.
After experiencing the Progressive springs there is no way I would go back to stock straight rate springs.
Old Jul 3, 2015 | 02:31 PM
  #33
Lucky Luke's Avatar
Lucky Luke
I meant "progressive" rather than Progressive™.
Sag, that was the word I was looking for.
Old Jul 3, 2015 | 04:00 PM
  #34
Beemervet's Avatar
Beemervet
Sag is adjusted by the length of the PVC preload spacer. It is not usually necessary. Progressive progressive springs, whatever. They work.
Old Jul 3, 2015 | 10:02 PM
  #35
WP50's Avatar
WP50
Put more down as a +1 on the progressive springs. Do use their recommended length on the spacer
WP
Old Jul 5, 2015 | 04:17 PM
  #36
Crashone's Avatar
Crashone
I've got a question for you guys on these springs. What is the difference between the standard springs and the Heavy Duty springs? Would running a pair of Heavy Duty springs be a better option for the 96 Road King as it is a heavier bike? I need to do something, I want to get rid of the air shock front ride and the diving front end on braking. I have already replaced the fork oil with DelRay #15. I have also installed a set of 440 progressive shocks on the back.
Thanks for the help.
Old Jul 5, 2015 | 05:48 PM
  #37
Beemervet's Avatar
Beemervet
You need stock length Progressive springs. Most that go with the heavy duty find them to be too stiff.
Old Jul 6, 2015 | 03:03 PM
  #38
DeputyLoud's Avatar
DeputyLoud
Diddo! My HD Progressive springs are indeed too stiff. Although I was ale to basically eliminate the antidive system altogether. There is no dive when stopping now, or very little anyways. But the ride could be smoother for sure. I want to get some RaceTechs installed sometime. But not really looking forward to ripping off the front end to do it.
Old Jul 6, 2015 | 03:32 PM
  #39
Crashone's Avatar
Crashone
Thank you for the information and letting me slightly highjack this thread.
Old Jul 6, 2015 | 04:29 PM
  #40
98hotrodfatboy's Avatar
98hotrodfatboy
I can understand that no one wants front end dip on breaking but one needs to understand that it is actually necessary to be able provide the proper amount of weight on the front wheel when braking (especially hard braking). The front wheel actually displaces 60% of the braking ability of your bike. and when you change the weight ratio aren't you changing the braking characteristics of the bike?
