Softail ignition switch
Old Jul 9, 2015 | 02:54 PM
Khshockey44's Avatar
Khshockey44
Default Softail ignition switch
Is there any way to use an ignition switch from a 96 and newer bike in place of the one that I have on a 95 heritage?
Old Jul 9, 2015 | 04:18 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Not without extensive rewiring.
FYI don't buy a cheap one from the aftermarket shops.
I bought 2 and neither lasted more than 6 months.
Just bike the bullet and get a new OEM one. You will be much happier in the long run.
Old Jul 9, 2015 | 05:36 PM
Khshockey44
The whole bike is getting re-wired and I can't find the key for the one I have and I like the newer style ones. Will it mount on the same location if I use spacers to raise it up?
Old Jul 9, 2015 | 05:41 PM
texashillcountry
Dirt don't hurt
It mounts in the same place but I'm not familiar with the mounting bracket.
You know you can have a locksmith make you a key for way cheaper right??
Personally I don't use the ignition lock because I know it can be easily defeated with a large pair of channel locks.
A good padlock on the neck works way better than the POS ignition lock.IMO
Old Jul 9, 2015 | 06:02 PM
Khshockey44
I thought they mounted a little differently. And I figure anything go slow a would be thief down is for the better.
Old Jul 9, 2015 | 06:18 PM
Joe_G's Avatar
Joe_G
To answer your question, yes, my 2003 switch worked fine on my 1995 touring bike, they are the same. Wait - if you've got the cable speedometer, no, they don't interchange. If you've got digital speedometer with digital odometer, yes they do.
But listen to texashillcountry, he's 100% right. Though my locksmith failed the first time, barrel keys are tough to make.
The second time I got stranded for a gummed up ignition switch, I paid attention to how they work when I took them apart.
I'm not going to say on the internet how to hot wire a harley, but suffice to say, ½ wrench or pliers for the console bolt, remove the console and there's only three wires there. They are amazingly easy to hot wire. I never tried channel locks but I guess that's even easier.
A much better theft deterrent is your fork lock. I don't know if your bike has the hoops but if it does, the circle locks are a lot harder to get off, it's tough to get bolt cutters on them.
I don't even lock my ignition anymore, just my forks.
Old Jul 9, 2015 | 06:25 PM
texashillcountry
Dirt don't hurt
With channel locks you don't even have to take the console off.
You just grab the switch and twist (type of key won't matter) and it will break the lock.
Yeah the fork locks is what I was talking about when I said the neck.
For some reason I couldn't think of the right name.
I completely agree with your last sentence.
98glider
EVO
Aug 2, 2017 08:32 AM
Airframer
Aug 9, 2016 11:03 AM
OG1
Mar 7, 2009 11:35 PM
F1J1
Jul 14, 2007 07:28 PM
mjenk430
Sep 11, 2006 07:34 PM
