carburator
Old Aug 21, 2015 | 11:01 AM
Dan Pecoraro's Avatar
Dan Pecoraro
Stage II
Default carburator
1987 Harley tour glide klien carburetor rebuilt, when I let off of throttle and get back on it it hesitates for a second, any suggestions ?
Old Aug 21, 2015 | 11:27 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Check accelerator pump adjustment.
Old Aug 21, 2015 | 11:32 AM
Dr.Hess's Avatar
Dr.Hess
There is no accelerator pump adjustment on that POS carb. The circuit might be plugged up or the diaphragm bad or something else going on there, but no adjustments. Also check for a vacuum leak.
The correct fix is to remove the Keihin butterfly carb and sell it for scrap aluminum at the recycler. Take the $.50 you get from that, add more money and buy a good carb like an S&S or a CV.
Old Aug 21, 2015 | 03:00 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
It costs more but I would go with the S&S myself.
Old Aug 24, 2015 | 08:09 AM
falconbrother's Avatar
falconbrother
Perfect tune on a butterfly carb is tossing it in the dumpster without hitting the sides. Mine is at the city dump. The S&S will cure all issues and give you more real world power.
Old Aug 24, 2015 | 04:42 PM
tomfiii's Avatar
tomfiii
Sometimes the needle under accelerator pump nozzle doesn't seat properly ,but you probably need a rebuild and replace gas lines if over 3 years old with low pressure fuel injection hose.
Pfarley1
Carburetor Related
19
Sep 13, 2024 11:15 PM
Ironhead Dave
Ironhead
25
Jul 11, 2016 09:35 AM
br549A1
EVO
Apr 8, 2015 09:37 AM
chardagha
EVO
May 3, 2010 04:28 PM
ShovelMike
Exhaust System Topics
Apr 2, 2005 01:36 PM
