Carby help on my EG
Old Aug 24, 2015 | 09:08 PM
0maha's Avatar
0maha
Default Carby help on my EG
Tore into my carb tonight. Cleaned it up, replaced the jets, etc.
All is good except for the life of me I can not see how I am ever going to get the VOES feed tube reconnected. There is like zero slack on the tube. It won't even reach unless the carb is fully seated, and then there is no room to work.
Is there some trick I am missing?
Old Aug 24, 2015 | 09:18 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Long noes pliers or take the tank off and it is easy to reach.
Depending on how long that hose has been on there you might consider replacing it.
Old Aug 24, 2015 | 10:23 PM
0maha's Avatar
0maha
Long is right. My regular, long nose ones were no good.
Ended up down at Lowes and got some crazy long ones with a 45 degree bent tip. That was the ticket.
Thanks!
Old Aug 24, 2015 | 11:58 PM
Spanners39's Avatar
Spanners39
Replace the hose with a longer one.....................
Cypunk
Apr 21, 2015 01:59 PM
Yachtman
Mar 18, 2010 02:53 PM
HD/GTO
Aug 18, 2009 08:15 PM
ernofsteel007
May 24, 2009 05:42 PM
cHarley
Feb 24, 2007 10:55 PM
