Clutch/Transmission gremlins.
Old Oct 3, 2015 | 05:42 PM
  #31
tmanbuckhunter's Avatar
tmanbuckhunter
FSM days 1/2-full turn, sorry.
I found some bad galling in the side cover, and the snap ring wasnt oriented right, but the ***** were all in place. Going to pull the clutch and see from there.
Old Oct 3, 2015 | 06:58 PM
  #32
tmanbuckhunter
Snap ring on the back of the clutch is in place. Unfortunately, I can feel the loose rivets causing **** to rattle, so that is the issue. I will pull the pack out soon and keep you all updated. Pics to follow.
Old Oct 4, 2015 | 09:46 PM
  #33
tmanbuckhunter
The galling in the side cover. Replace or is it ok? Like I said, the ***** were in the ramp.
Old Oct 6, 2015 | 03:51 AM
  #34
Spanners39's Avatar
Spanners39
See how smooth the mechanism works first, the galling shouldn't matter because the movement doesn't occur where the galling is.
Old Oct 6, 2015 | 08:25 AM
  #35
tmanbuckhunter
That is true. I looked at the edges of the ramps and they were smooth along the sides... mechanism works well. I will get a gasket, throw out bearing, and put it all back together soon. I still haven't pulled apart the clutch hub yet to see what is loose in there but I think you all hit the nail on the head.
Old Oct 6, 2015 | 08:56 AM
  #36
flhchaz's Avatar
flhchaz
Some thick grease helps hold everything in place while putting the ball and ramp together.
Old Oct 6, 2015 | 09:06 AM
  #37
tmanbuckhunter
Thanks for the tip. Pesky little buggers aren't they?
Old Oct 6, 2015 | 10:03 AM
  #38
flhchaz's Avatar
flhchaz
Can't say that I never chased one of those across the garage floor before.....
Old Oct 6, 2015 | 10:06 AM
  #39
QC's Avatar
QC
The thing that bothers me in that pic is a piece of material inside the snap ring groove. Is that a burr, displaced material, junk, or what?
Old Oct 6, 2015 | 03:00 PM
  #40
tmanbuckhunter
Just displaced material; I went and looked.
