Clutch chirp (when cold)
Old Oct 14, 2015 | 10:33 AM
falconbrother's Avatar
falconbrother
Default Clutch chirp (when cold)
My clutch works fine but..when the bike is cold it chirps when starting/engaging from a dead stop. It has been doing this a long time but, as it's getting colder out it seems to last a little longer. What is that? Once the bike is fully hot it quiets down.
Old Oct 14, 2015 | 03:20 PM
tmanbuckhunter's Avatar
tmanbuckhunter
Spun hub bearing. Another quality harley davidson product.
Old Oct 14, 2015 | 07:27 PM
glidein wide's Avatar
glidein wide
Sure it's not your rear belt at the front pulley ?
Old Oct 14, 2015 | 07:29 PM
Jethro's Avatar
Jethro
I would also look at your rear belt adjustment
first.
Old Oct 14, 2015 | 07:50 PM
Ruggs59's Avatar
Ruggs59
I would also say check the belt, Take a wax candle and rub the side of the belt with it and see if the chirp goes away. Cant hurt to try it.
Old Oct 14, 2015 | 07:52 PM
1997bagger's Avatar
1997bagger
It is your belt slipping on the trans pulley, kinda like a violin effect. Belt is getting older and harder, temperature is also making it harder. When you slow down to a stop using gearing, it will do it worse because the belt walks some and walks the other way when you take of, I have actually pulled the clutch back in because i thought something was wrong.
Old Oct 14, 2015 | 07:57 PM
tmanbuckhunter
Yep...
Check the belt first.
Old Oct 14, 2015 | 08:30 PM
glidein wide
Dry graphite spray, Napa, also works well for belt chirp.
Old Oct 15, 2015 | 10:45 AM
falconbrother
I'm pretty sure it's not the belt. When I start it up from cold I let it warm up a bit, usually quite a bit. Then kick it into first and let out the clutch it makes a sort of rubbing chirp sound. It will do it the first couple of times and then not again all day unless things get bone cold again. There's no diminished clutch function. Wondering if maybe a warped clutch plate would cause that.
Old Oct 15, 2015 | 07:08 PM
glidein wide
Still thinking it's the belt until you eliminate the possibility by lubricant or spray of some sort.
Start small with process of elimination.Does it make the noise before the bike starts to roll while letting out the clutch?
