Finding Neutral?
Old Oct 22, 2015 | 04:24 PM
0maha's Avatar
0maha
Originally Posted by Tom84FXST
I usually find if clutch adjustment is not the culprit...the primary chain is too tight.
Interesting tip. I'll let you know how it works out. Thanks!
Old Oct 22, 2015 | 05:05 PM
bluharley's Avatar
bluharley
Which neutral are we talking about? Between 1st and 2nd is a b!tch, the others are pretty easy.
Old Oct 22, 2015 | 05:21 PM
glidein wide's Avatar
glidein wide
My four speed ratchet is never a problem,1st to neutral or 2nd to neutral. Almost never look down at light either, I just know when it's there.
A habit I have is put it in before stopped, slow roll. If I'm sitting at a light too long or something I'll let the clutch out a little then pull it in and theeeerrrre she is.... no throttle blips....
Old Oct 22, 2015 | 05:35 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I have never been able to get more than .065" clutch release which does make for difficult neutral location. You will need to measure the amount of throw at the clutch pushrod adjustment screw. Technically you should have .080" for proper clutch disengagement. Anything less than .070" will make it hard to find neutral at a stop. I've tried everything even a new 21* ramp at the trap door and I still get .065". Anyone know of any clutch lever manufacturers that will give more throw than an oem clutch lever?
Old Oct 22, 2015 | 05:39 PM
joebedford's Avatar
joebedford
Wifey's '96 Ultra has always been a bear to get into neutral (when stopped). Since I switched to H-D synthetic in the primary it's been a bit better.
defiantdadeo
Jun 15, 2019 07:15 PM
RSDUDA
Mar 15, 2015 12:38 PM
harley1985
EVO
Aug 17, 2009 02:27 PM
Skygoose
Mar 9, 2009 12:15 PM
Bass Ackwards
May 17, 2008 01:35 PM
