Finding Neutral
Old May 14, 2008 | 10:16 AM
Bass Ackwards's Avatar
Bass Ackwards
Default Finding Neutral
Is it just me, or are others having this same trouble??[sm=wtf.gif] I'm riding an '00 UC, and I seem to always have trouble finding neutral when I'm on the road. I like to slip it into neutral, if I'm sitting at a long light, so I don't have to sit there forever holding the clutch in, or if I wanna light a smoke. But finding neutral can be a real pain in the ***!! [:@] So any insight would be most helpful!
Thanks!!
[IMG]local://upfiles/60212/218A334BE2C3461DB25FBA52B440923A.jpg[/IMG]
Old May 14, 2008 | 10:20 AM
irishviking's Avatar
irishviking
Default RE: Finding Neutral
Change out your primary oil to 75-140 gear oil and tap down from 2nd instead of up from 1st.
Old May 14, 2008 | 10:22 AM
etreulich's Avatar
etreulich
Blipping the throttle (just a little)while shifting always works for me.-Eric
Old May 14, 2008 | 10:23 AM
Bluesssman's Avatar
Bluesssman
I agree with taping down from 2nd, works well for me. However, I was told to never use gear oil in the primary...
ORIGINAL: irishviking
Old May 14, 2008 | 10:24 AM
RoadKing_Al's Avatar
RoadKing_Al
Took me awhile. From 1st gear I just slide my boot under the shifter and push forward, to use the boot as a wedge, It's second nature now.
Old May 14, 2008 | 10:27 AM
Erdnase's Avatar
Erdnase
For me it was a feel thing. It'll come after a while. It just takes practice. The more you ride the better you get. Ride often!
Old May 14, 2008 | 10:31 AM
Copper Hog's Avatar
Copper Hog
I give it just enough throttle to roll it forward a few inches. While it's inching forward pull the clutch and it slips right into neutral. I just changed over to synthetic and that seemed to make it much easier.
I'm with ya though. Seems like a lot to have to go through to find neutral.
Old May 14, 2008 | 11:05 AM
rk99's Avatar
rk99
I had this problem on my 99 RoadKing.. Had the 10K checkup which involved some adjustment...after I got it back, I had NO PROB with finding neutral...
Old May 14, 2008 | 11:09 AM
2008FLHP's Avatar
2008FLHP
primary? or do you mean tranny?
Old May 14, 2008 | 11:41 AM
DeJavu's Avatar
DeJavu
ORIGINAL: rk99
+1, most problems with neutral are associated with clutch drag. If your lever play is more than 1/8" at the handlebar you may not be fully disengaging. If the play is right you may be running too thick an oil. If all that is right there is a chance you have a warped or unevenly worn clutch plate. If that is all OK your clutch pressure plate springs may be worn or broken.
Hopefully, a proper adjustment of your cable or clutch arm will take care of it.
