Finding Neutral
Old May 14, 2008 | 07:46 PM
1of2's Avatar
1of2
"Moderator"
Default RE: Finding Neutral
I had a lot of problems when it had the Harley oil in it. Once I went with Mobil 1 the problem went away. Now it slides in like butter. I don't even have to look for the light. I just know it is there. I have since switched to Amsoil in the crankcase but will keep the Mobil in the tranny. It is smooth as silk.
Old May 14, 2008 | 07:49 PM
Navitimer's Avatar
Navitimer
IMHO its mostly practice and really getting a feel for it. Nine times out of ten I can stop at a light and pop it into neutral without even looking - you just know the feel and you can tell that its not in second (I always find mine by going up from first). I know not looking is not a best practice...now I've probably jinxed myself...ha! Very rarely I'll have to engage the clutch just slightly while in first to get a slight rotation if neutral is being difficult, but again its fairly rare this happens.
Old May 14, 2008 | 08:03 PM
flyingace's Avatar
flyingace
Hmm
Thats kinda funny, I have better luck tapping up from first. Can NEVER hit it coming down from second. Mine got noticeably harder after the 1000 mile checkup, when it got changed to syn3 in the trans. And It got harder again after I added the IDS. (the only downside I've found to that mod)
Old May 14, 2008 | 08:25 PM
Taterdog's Avatar
Taterdog
I had the same problem with my 2000 FLHTCI. Be sure your primary chain is adjusted properly, then blip the throttle when you lift your foot shifter. Mine goes into neutral everytime now -- no problems.
Old May 14, 2008 | 08:44 PM
safxdb's Avatar
safxdb
make sure that the clutch is adjusted correctly at the push rod. very easy adjustment also.
Old May 14, 2008 | 08:53 PM
Hugh Jass's Avatar
Hugh Jass
I've alway had this issues with all my bikes. I'm glad I'm not the only one... [:@]
Old May 14, 2008 | 09:34 PM
pdexter's Avatar
pdexter
im asuming you have downshifted to a stop and in first gear, then use the heal shift not your toe much easier
Old May 14, 2008 | 09:35 PM
iclick's Avatar
iclick
While in first gear, just nudge the clutch lever enough to cause the bike to move slightly. Then click it into neutral. Worked every time for me on my old Evo RK, but my '07 SG goes in much easier.
Old May 15, 2008 | 01:10 PM
Johan96's Avatar
Johan96
ORIGINAL: Buckeye Biker
Roll it forward a bit. Works for me.
[IMG]local://upfiles/59266/C8ADB1E78DAC443193AA8BCA839DD5AC.jpg[/IMG]
Or an inch back. Works fine on my 2000 Lowrider
Old May 15, 2008 | 01:58 PM
spacelord's Avatar
spacelord
ORIGINAL: pdexter
+1
Heel shifter. First time every time. Of course until now that I have typed this!
