Finding Neutral
Old May 14, 2008 | 11:52 AM
RK_Dave's Avatar
RK_Dave
Default RE: Finding Neutral
I have the same issues and everything is fine on mine. Been a pain since everything (Motor, Tranny & Clutch) was new! I run Redline Synthetic in mine. It's still a bitch to find. But like others have said, it is easier to find, coming down from 2nd.
Dave...
Old May 14, 2008 | 01:12 PM
IRideMineEverywhere's Avatar
IRideMineEverywhere
Come into neutral from second on your slow down for a light at slightly higher RPM's.... Your bike doesn't want to go into first on a downshift and will stop at the neutral position... something to do with the way the gears are sync'd...I've been doing it since I learned to ride with no problems....
Not sure if that's a clear explaination, but it's the only way I can explain it.
Old May 14, 2008 | 01:16 PM
roxnatwist's Avatar
roxnatwist
Don't feel like the Lone Ranger- I've got the same thing on my 07 RKC. Had it on my 03 RKC also. I think it's just one of those things you have to get used to. I'll be trying some of the tricks mentioned here to see if it helps.
Old May 14, 2008 | 01:40 PM
Night Crawler's Avatar
Night Crawler
The only time I use the heel shifter is when I go into neutral from 1st gear.
Took me a while to discover it but it’s a natural for me now.
Old May 14, 2008 | 01:46 PM
anubisss's Avatar
anubisss
Try adjusting the clutch on the cable. Very simple and takes about 2 minutes.
Old May 14, 2008 | 04:52 PM
Ultra Rider 03's Avatar
Ultra Rider 03
You really should not be trying toshift your trans while not moving. Meaning shift down from 2nd coming to a stop. Clutch drag and just the design of the trans says bestnot to shift while not moving.
Old May 14, 2008 | 05:12 PM
Buckeye Biker's Avatar
Buckeye Biker
Roll it forward a bit. Works for me.
[IMG]local://upfiles/59266/C8ADB1E78DAC443193AA8BCA839DD5AC.jpg[/IMG]
Old May 14, 2008 | 05:54 PM
Wally's Avatar
Wally
ORIGINAL: etreulich
Blipping the throttle (just a little)while shifting always works for me.-Eric
Try this it works like a dream.
I switched to amzoil in the transmission and it helped with all shifting.
Old May 14, 2008 | 06:24 PM
peddler's Avatar
peddler
For me it was a feel thing. It'll come after a while. It just takes practice. The more you ride the better you get. Ride often!
Exactly! No matter what gear oil you use in the transmission, it's practice, practice, practice.
Old May 14, 2008 | 07:07 PM
Lincoln33's Avatar
Lincoln33
I had the same problem with my bike. I had my hot and cold idle adjusted to idle at 1000 rpm and I haven't had the problem since. FYI I wasn't trying to fix the neutral problem when I had the idle adjusted it was just a benefitwhile correcting another problem.
