for my own sanity
Old Dec 7, 2015 | 01:53 PM
WVICEMAN's Avatar
WVICEMAN
Default for my own sanity
I have an 85 FLTC I've been bringing back to life. It runs well but is a little noisy and I think for my own sanity I'll change the cam bearing and lifters to be on the safe side. Am I being paranoid? I don't know the history of this bike or the life it has led.
Old Dec 7, 2015 | 02:04 PM
IBDAGRIZ's Avatar
IBDAGRIZ
Sounds like a good game plan to me. I would also throw in something with a little more pep in it cam wise since I was in there already if it was me.. And funds allow.
Griz
Old Dec 7, 2015 | 02:18 PM
bluharley's Avatar
bluharley
After 10 years and ?????? miles, I'm still waiting for my evo to fly apart, never got used to the noises.
Old Dec 7, 2015 | 03:01 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Griz
Old Dec 7, 2015 | 03:09 PM
Dr.Hess's Avatar
Dr.Hess
Lifters, yeah, you need to swap those out. Cam bearing, no, you have the good one in there already, unless someone swapped it to the no-so-good one. Certainly inspect it when you have it apart, if you take it down that far. Also inspect the cam, as if a lifter is gone, the cam will probably be gone also.
Old Dec 7, 2015 | 05:28 PM
johnjzjz's Avatar
johnjzjz
i have seen INA cam bearings in pan heads for some reason - to add to your list would be the bushings in the rocker arms - and maybe even valve guides - fresh set of pistons and your good for another 50 if you drive like a humanbeing
Old Dec 7, 2015 | 05:29 PM
traildog's Avatar
traildog
I'd go for it!
Old Dec 7, 2015 | 06:25 PM
glidein wide's Avatar
glidein wide
Spend the money and have some fun !!!
I did swap out my cam bearing for piece of mind,$10. From the stealer and It didn't feel and snugger on the old cam,but I know it's new now. Fwiw
Old Dec 8, 2015 | 06:14 AM
grbrown's Avatar
grbrown
Many years ago a local dealer had on display a con-rod with the bearing journal jammed tight in it, removed from the flywheels. I think it was out of a Matchless single, the rollers had ground down against each other, then climbed over each other until the lot welded itself together. The owner had ridden his bike until it finally stopped, engine seized thanks to that rod bearing. Doesn't sound as if yours has got that far yet......
Try a set of ear plugs - best tuning aid known!
Old Dec 8, 2015 | 06:54 AM
texashillcountry
Dirt don't hurt
I change mine out every time I go in that far.
It's cheap and gives me piece of mind.
