Carbs
Old Dec 11, 2015 | 08:28 AM
bigpappa160's Avatar
bigpappa160
Default Carbs
I have a 91 ultra classic, I was reading service manual this morning about idle rpm's. The reason I was looking at this in the manual I noticed after riding bike for about 15 min I stopped at a traffic light and the rpm's at idle was around 600-700 rpm's. I was reading service manual and it said that normal idle rpm speed should be 1000. I also read if the rpm's isn't at 1000 adjust idle speed to reach 1000. I probably already know the answer, but just wanted to make sure with people with a little bit more knowledge. Do I turn the idle screw clockwise to increase and counter clockwise to decrease?Like I said I read the manual but it doesn't say anything of how many turns or which way to turn, it just says adjust.
Old Dec 11, 2015 | 08:39 AM
0maha's Avatar
0maha
You have it right. In any case, you'll know right away if you have it wrong.
Make sure the engine is up to full operating temperature, give her a bit of adjust. Blip the throttle a few times to let her settle in. Adjust from there. There's no fixed "number of turns". Just adjust it until you have the idle where you want it.
Old Dec 11, 2015 | 09:06 AM
bigpappa160
Just finished it and it's backup to 100. But seeing that Harley shop suppose to do a carb recall work on it tomorrow I could have let them do it, but I wanted to adjust idle to give me a warm fussy feeling when I'm stopped at idle and it doesn't sound like it's about to shutoff. Thank You for help
Old Dec 11, 2015 | 10:37 AM
0maha's Avatar
0maha
What's that about?
Old Dec 12, 2015 | 04:22 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
If the welch plug that blocks the air/idle screw has not been removed to access that circuit, it needs to be removed/discarded and the air/idle screw needs to be set at 2 1/2-3 turns out.
Then set the idle at approx 1000 rpms.
Scott
Old Dec 14, 2015 | 03:55 PM
bigpappa160
Sorry Omaha Let me find my recall paper I'll let ya know
Old Dec 14, 2015 | 04:05 PM
bigpappa160
Sorry Omaha, I never got your question on my phone update. But the recall was issued back Nov 30, 1992, NHTSA Campaign Number 92V173000, Component: Fuel System. The Fuel Inlet Needle does not seal properly against the fuel inlet seat. The HD shop said if the carb is concentric it was a simple replace fuel inlet needle. If the carb is non concentric they have to replace the carb. Which I hope it's non concentric so they can put a newer carb in it, which they found one that's a 98. I'll let you know later of what up with that. Just took it in this past Sat.
Old Dec 14, 2015 | 04:10 PM
Kees's Avatar
Kees
I think they'll be giving you a bill after they have done the work.
Old Dec 14, 2015 | 05:01 PM
bigpappa160
No Sir Kees, I asked them if they had to replace the carb would there be any charge and the service manager said he would see that there was no charge. I know I should've got it in writing. But, we'll see
ausmith73
May 2, 2008 06:30 AM
08HD
Apr 25, 2008 09:00 PM
J.J.
Mar 14, 2008 09:33 AM
HeliRider
Sep 1, 2006 02:23 AM
dlongo8241
Feb 19, 2006 12:41 AM
