Brake Upgrade
Old Jan 9, 2016 | 11:41 PM
  #31
Owtlaw's Avatar
Owtlaw
Originally Posted by langwilliams
On that brake line being too short....do you have stock bars? My fatboy has low bars an I'm wondering if the stock line will work until I can get braided lines. I have a set of those calibers in black....thinking of ordering a plain adapter plate an painting it black.
I do have stock bars, but it wouldn't really matter in my case because the part that was too short was south of the splitter for the dual discs. I suspect a single disc setup would be more forgiving in line length.
Old Jan 14, 2016 | 03:12 AM
  #32
stephtell's Avatar
stephtell
Used to absolutely HAMMER my FXDX everywhere and it was great!
Proper sportsbike!
Old Jan 15, 2016 | 04:26 AM
  #33
Grog's Avatar
Grog
When you go from the two piston to the four piston setup doesnt the master cylinder need to be upgraded as well?
Old Jan 15, 2016 | 04:59 AM
  #34
grbrown's Avatar
grbrown
Wink
Not necessarily. It's all down to total piston area. On my Evo Glide I have twin 6-pot calipers, which replace the original twin-pot ones, using the same master cylinder. On my rear brake I have replaced the original single-piston caliper with a 4-pot, again with the same rear master cylinder. H-D seems to have maintained that balance since Evo days right through until very recently. I understand the current Brembo calipers on the big twins use different size master cylinders, their first change for around 20 years or so.
So using Harley components you should be fine, only if going to a radical change of calipers is the master cylinder likely to be a problem.
Old Jan 15, 2016 | 06:20 AM
  #35
Schex's Avatar
Schex
I have the Brembo calipers front and rear with the original master cylinders with no problems, using dot 5 fluid also.
Old Jan 15, 2016 | 06:23 AM
  #36
grbrown's Avatar
grbrown
Thumbs up
That's what I plan as well! Collected my 'new' rebuilt forks with Ohlins cartridges today! One small step....
Old Jan 15, 2016 | 07:45 AM
  #37
Owtlaw's Avatar
Owtlaw
As stated above. I'd add that if you go from single disk to duals is when you need the larger master, according to what I hear. I've never done that particular upgrade.
Old Jan 15, 2016 | 07:53 AM
  #38
grbrown's Avatar
grbrown
Thumbs up
That is true. Doubling calipers is a 'radical change'! Although they both look the same, the MoCo make single and twin caliper master cylinders.
Old Feb 7, 2016 | 11:38 AM
  #39
Owtlaw's Avatar
Owtlaw
Test drive complete. Huge difference in stopping power. It's nice to know I can actually lock up the front wheel, but it was interesting discovering that I could. I've got more lever travel than I'm used to, so I'll bleed another session or two to be sure. It may just be a different feel that I have to get used to.
Just a quick update. The increased lever travel persisted for a couple of rides, then settled into a short travel, rock hard lever just like I was used to. I'm guessing the DOT5 had some bubbles embedded that took a while to work out. Very happy with the new braking performance.
Old Feb 7, 2016 | 02:10 PM
  #40
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That's interesting.
Mine has stayed long travel.
