Belt life
Old Jan 21, 2016 | 07:01 AM
Baja272's Avatar
Baja272
Default Belt life
I bought a 1998 fxsts last year and it only has about 6000 miles on it. I have a feeling it's the original belt, it looks fine but just wondering if the age would effect it. Should I worry about it or just change it for piece of mind. It looks like it will be a fun job to do but it's winter here in new York so it's just sitting there anyway
Old Jan 21, 2016 | 07:04 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Not necessary......
Old Jan 21, 2016 | 07:18 AM
bagga's Avatar
bagga
if it ain't broke, don't fix it.
Old Jan 21, 2016 | 08:37 AM
Dr.Hess's Avatar
Dr.Hess
My current belt was put on about 1990, 1991 or so. It is my third. I stopped doing wheelies when this belt was put on.
Old Jan 21, 2016 | 08:52 AM
Uncle G.'s Avatar
Uncle G.
I usually change mine out between 80,000 and 90,000 for peace of mind. At 200,000 on my bike I'm on my third belt.
Old Jan 21, 2016 | 11:13 AM
grbrown's Avatar
grbrown
Difficult one! It's 28 years old. I've only once replaced a belt because I felt I had to, due to stone damage, so haven't endurance tested one for that sort of age. We often recommend new owners of very old bikes to replace tyres, oil/fuel pipes etc and I for one would probably change the belt if that bike were mine. It is indeed a fun job to do that. Personally I get my local friendly indy to do those sorts of job, but if you fancy tackling it yourself do use the factory service manual, if you don't have one. You don't quite have to start by removing the headlight bulb, but.......
Old Jan 21, 2016 | 01:51 PM
Kabear's Avatar
Kabear
Got 115,000 on my original belt, it failed because the outer "rubber" coating was compromised and allowed H2O in and rusted two of the three steel belts.
If exterior is intact and not damaged in any way it may be good, a tedious job to replace and the belt isn't cheap, instead buy roadside service and ride, if it breaks let the service pay for the pick-up and belt replacement.
Just my .02
Old Jan 21, 2016 | 06:56 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by grbrown
It's 28 years old.
Dog years? Mayan calendar? If I was planning any long trips, I would replace it just to feel better...age affects rubber as much as miles.
Old Jan 21, 2016 | 07:16 PM
Hackd's Avatar
Hackd
Still got the original belt on my 1993 FLHS. 57,XXX miles. Picked up a small stone in 1994, pushed it out with an ice pick. Those belts are tough.
However, my son snapped one on the 883R he had. Luckily he was in his driveway when it happened.
Old Jan 22, 2016 | 04:01 AM
grbrown's Avatar
grbrown
Talking
Harleys ain't no dogs - they're hogs.....
