Belt life
Old Jan 22, 2016 | 05:44 AM
Notgrownup's Avatar
Notgrownup
91000 off my original on my 07... Not really concerned, looks good still...If I wold take the swing arms To change the bushings for example I would probably change it.
Old Jan 22, 2016 | 08:40 AM
Uncle G.'s Avatar
Uncle G.
Conversely, while you're changing the belt, it's a good idea to change the swing arm bearings.
Old Jan 22, 2016 | 09:12 AM
Notgrownup's Avatar
Notgrownup
Yep...
Old Jan 23, 2016 | 11:23 AM
Baja272's Avatar
Baja272
Thanks for the replies. I do have the rear tire and fender off anyway so maybe I will just go ahead and replace it. The swingarm dosnt look that hard to take off and I do have a service manual
Old Jan 23, 2016 | 11:34 AM
bagga's Avatar
bagga
you need to remove the inner and outer primary plus the primary chain and the clutch pack too. it's not as simple as just removing the swing arm.
Old Jan 23, 2016 | 01:40 PM
0maha's Avatar
0maha
And on a high miles/years bike, there are a bunch of "may as well as long as its opened up" items you might want to consider.
Old Jan 23, 2016 | 03:01 PM
Baja272's Avatar
Baja272
Yea I was just flipping through the book and it's a little more involved then I thought. Think I will still do it can't be that bad and even though the miles are low it would be nice to give everything a look
T Man
Jul 30, 2019 05:56 PM
madwrencher
Feb 3, 2019 08:36 AM
bikemiser
Aug 19, 2011 06:12 PM
GlennsGlide
Aug 9, 2007 10:55 AM
DieHard
May 2, 2006 08:01 AM
