Clutch Replacement
Old Mar 7, 2016 | 05:54 PM
tmanbuckhunter's Avatar
tmanbuckhunter
Originally Posted by 1997bagger
Wood blocks and wire ties?
A piece of all thread that will slide through the hub, double nutted on the bottom with a lock washer in between the double nuts, with a flat washer on top of that. Slide the hub on, then slide on a 3" PVC cap with rectangle windows cut out to allow access to the snap ring and retaining ring with a flat blade. Slide on a flatwasher on top of the PVC cap, then another nut and then compress the spring until you can get the snap ring out. Snap ring on the back side of the hub holds it into the bearing so it's not going anywhere. Snap ring and retaining ring can be put back in by hand... no need for special tools. The only stipulation is that it does require that the whole entire clutch hub comes off.
Old Mar 7, 2016 | 05:59 PM
1997bagger's Avatar
1997bagger
Good stuff, do they have shade trees in Texas?
Old Mar 7, 2016 | 06:01 PM
tmanbuckhunter
Nope.
Clutch removal tools brought to you by BAWB (broke *** white boys) Racing.
Old Mar 7, 2016 | 06:28 PM
1997bagger's Avatar
1997bagger
Originally Posted by tmanbuckhunter
Nope.
Ya, can relate to that, have a few Redneck engineering tooling myself
Old Mar 8, 2016 | 07:25 AM
BlindRiverBagger1340's Avatar
Thanks for the input guys swaying towards Barnett
Old Mar 8, 2016 | 07:32 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Been trouble free in my bike for 5 years running.
Klever5
Apr 13, 2017 05:28 AM
zyban
Dec 21, 2014 08:08 AM
RidemyEVO
Feb 27, 2010 06:04 PM
CDN. RG
Nov 16, 2008 07:36 AM
sportyrider1
Feb 11, 2007 10:45 PM
