evo base gasket
Old Mar 11, 2016 | 07:13 PM
rpal852's Avatar
rpal852
5th Gear
To tell the truth Im not sure where its venting. Im at work but will check it out. Is it possible for it to just start making noise?
Old Mar 11, 2016 | 07:15 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Yes
It usually means something is wearing out.
As mentioned above new lifter and cam bearing before you start it again.
Old Mar 11, 2016 | 07:20 PM
rpal852's Avatar
rpal852
5th Gear
Ok got a few ideas. Think I will tear her down. Bought it in 2000 and case never been open. Will replace gaskets and check stuff over. Thank you everyone for your help.
Old Mar 11, 2016 | 07:22 PM
Dr.Hess's Avatar
Dr.Hess
You don't have to open the cases, just pull the cone and the rocker boxes. If you're going to fix the base gasket at the same time, then keep your existing push rods.
Time to get the official factory shop manual.
Old Mar 11, 2016 | 07:23 PM
glidein wide's Avatar
glidein wide
Haven't heard the noise before, but,does a bad bearing or lifter sound like walking in wet shoes when they go ?
Old Mar 11, 2016 | 07:36 PM
rpal852's Avatar
rpal852
5th Gear
Yes got the manual. Figure I may as well get that base gasket while I am there. Hopefully it will be happy for a while then. I can see the oil bubble out of the base when its hot.
Old Mar 11, 2016 | 07:37 PM
texashillcountry
Dirt don't hurt
What model bike do you have?
Old Mar 11, 2016 | 07:41 PM
texashillcountry
Dirt don't hurt
If you're gonna tear it down that far I suggest putting in a decent cam while you are there.
Old Mar 11, 2016 | 07:45 PM
Dr.Hess's Avatar
Dr.Hess
If the lifters or the cam bearing are shot, the cam is probably shot too.
Old Mar 11, 2016 | 07:55 PM
rpal852's Avatar
rpal852
5th Gear
Almost looking like I should entertain the idea of doing a complete rebuild.
