How Often.........
Old Mar 30, 2016 | 01:19 PM
Schex's Avatar
Schex
or just a longer hose
Old Mar 30, 2016 | 02:07 PM
89FLHTC's Avatar
89FLHTC
Im not sure I understand. Are you filling the fork from the drain plug end or schrader valve? I dont see how the fork would fill up from the schrader valve with the drain plug installed. I think im missing something.
Old Mar 30, 2016 | 02:29 PM
Hackd's Avatar
Hackd
I do the wheel bearings with tire changes. Fork oil? Yeah. I did that once at 10,000 miles. Haven't done it since...
Old Mar 30, 2016 | 02:41 PM
daven9113's Avatar
daven9113
89FLHTC,
This is how I understand his description. You connect the mighty vac to the schrader valve. While pumping the mighty vac, you draw the oil into the fork through the drain hole which now has the tapered fitting inserted in it with a hose going into a container of new fluid. You would continue to pump the mighty vac until the new fluid has drawn up into the fork, then you replace the tapered fitting with your original plug, thus allowing little to none of the fork oil draining out. Probably much easier with a helper, unless you draw in an extra ounce and stop pumping while you replace your plug.
Sound right to you? Guess I need to visit Harbor Freights for a mighty vac. :-)
Dave
Old Mar 30, 2016 | 03:16 PM
89FLHTC's Avatar
89FLHTC
Dave, Now I get it. Thanks! Yes..sounds like that would work and work well.
Old Mar 30, 2016 | 04:57 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by daven9113
89FLHTC,
Dave
Damn that sounds complicated.
All I do is remove the fork cap, remove drain plug, after the fluid is out install drain plug, then fill through the hole in the top and replace the fork cap.
Old Mar 30, 2016 | 05:01 PM
89FLHTC's Avatar
89FLHTC
Yeah but getting to the fork caps on my is a lot of work. Its setup like a Road King.
Old Mar 30, 2016 | 05:18 PM
texashillcountry
Dirt don't hurt
From the picture in your avatar it looks like you have to take off your windshield, what else do you have to take off to get to the fork cap??
Old Mar 30, 2016 | 05:27 PM
89FLHTC's Avatar
89FLHTC
The headlight nacelle for one.
Old Mar 30, 2016 | 05:30 PM
texashillcountry
Dirt don't hurt
DAMN you gotta pull the nacelle to get to it??
What a PITA!!!!!
