Ratios
Old Apr 20, 2016 | 09:02 PM
MadBobber's Avatar
MadBobber
Default Ratios
Can someone further explain to me the difference between a primary setup a drive pulley setup in tegards to ratios and how a person calculates these ratios?
Old Apr 21, 2016 | 04:15 AM
Spanners39's Avatar
Spanners39
Calculate ratios as "driven over driver" so a 72 tooth pulley being driven by a 24 tooth would be a 3:1 ratio a 72 driven by a 25 will be a 2.88:1 ratio....1:1 is direct drive as in 1 RPM from the motor is 1 RPM at the input shaft of the tranny.
You can dial in a variety of ratios and a higher ratio (the lower the first number in the ratio the higher the gearing) will reduce revs across the range and also slow down your giddy up from the lights. You can usually buy your set up with a choice of ratios but work out what your bike is running currently before choosing your parts. It is usually the crank pulley (the smaller of the two) that you have a choice of.
Old Apr 21, 2016 | 07:11 AM
Owtlaw's Avatar
Owtlaw
Perfect description. You have 3 gearing ratios in a HD. Primary drive (clutch/compensator), Transmission (5th is 1:1 so can usually be ignored), and secondary drive (wheel pulley/transmission pulley). To get a final drive ratio you multiply all of these together.
http://www.hotbikeweb.com/motorcycle...vetrain-basics
SteveB1971
EVO
29
Oct 16, 2014 05:27 AM
ray2001
Mar 4, 2012 09:04 PM
Village Idiot™
Nov 18, 2011 07:23 AM
luvtoride
Oct 9, 2010 05:58 PM
up2nogood22
Jun 11, 2008 07:38 AM
