Hard to Shift
Old Apr 24, 2016 | 07:41 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I`m going to disagree with that. The five speed gears don`t need any type of super gear lube, they are very lightly loaded and will outlast the bike using any regular 85w90 gear lube.
I have a 1989 gearset on the bench with 115k on it (all it got was 85w90 conventional), and the gears look excellent.
I've always heard the 75w-140 was the best choice but I'm willing to take your word that 85w-90 is just fine.
Old Apr 24, 2016 | 07:57 AM
glidein wide's Avatar
glidein wide
Just fill it up on the kick stand and call it a winner. This is not surgery...
Ditto on the 85w-90 (Valvoline) for me...
Old Apr 24, 2016 | 10:09 AM
89FLHTC's Avatar
89FLHTC
Do I need Dextron III for the primary ?
Old Apr 24, 2016 | 10:36 AM
bagga's Avatar
bagga
i've used 20w50 harley motor oil, 85w90 and 75w140 in my trans, it's all the same as far as i'm concerned. i go to my local farm store and get their farm tractor gear oil and use that because nothing takes more abuse than a farm tractor gear box.
Old Apr 24, 2016 | 10:41 AM
texashillcountry
Dirt don't hurt
While I disagree with filling it on the kickstand it looks like I sit corrected (I am sitting on my *** while I type this after all) on the tranny fluid.
I will probably try filling it on the kickstand and then straightening the bike up to see where the level is with the bike upright just out of curiosity.
Old Apr 24, 2016 | 02:51 PM
Prot's Avatar
Prot
I am surprised nobody mentioned Redline Shockproof.
Old Apr 24, 2016 | 02:57 PM
Tommy C's Avatar
Tommy C
Now that you mentioned it I use Redline Shockproof. Seems to work fine. Who knows if it is better than any other synthetic gear lube.....
Old Apr 24, 2016 | 03:21 PM
89FLHTC's Avatar
89FLHTC
I think I got lucky. I had indeed overfilled the primary but about 1/2 a pint. Took it on a test run and it shifted fine. Fingers crossed!
Old Apr 24, 2016 | 05:37 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Here is the correct primary lube level for all big twins since late `84, it should not be higher than this, but a little lower won`t hurt a thing (bike vertical):
Old Apr 26, 2016 | 11:22 AM
89FLHTC's Avatar
89FLHTC
FIXED ! Found the primary chain adjuster loose and dropped down about 4 clicks. Re-adjusted and it shifts flawlessly. I can actually find neutral again. Actually fixed 2 issues. I also had a surge that I thought was due to a lean carburetor but turns out it was the loose primary chain. Thanks for all of the suggestions!
