Advice needed from the experienced.
Old Apr 25, 2016 | 05:37 PM
RaSh's Avatar
RaSh
Default Advice needed from the experienced.
Hello folks, I haven't posted here for a while, but my EVO is acting up and I need advice from those that know.
I started having trouble getting my starter to fire, I cleaned up my battery and starter contacts, which did not solve the problem, and became convinced that my start switch was the culprit.
It was rebuilt, and it wasn't.
I've been paying better attention to what get's me to a condition where the starter will fire, and now when I get no starter response I rotate my ignition fork lock lob off the Ignition position to the lights or accessory position and back, and so far it has fired up every time.
I suspect something is sticking, perhaps wearing out.
Can anyone tell me what I am going to see once I dig in there, better yet what is the most likely fix?
I'd like to be sure that I have parts available for the most likely problem.
So far I haven't found anything clear on-line, and the factory manual shows the mechanical parts and some sort of thickness gauge, but I am unclear about the switch, if it easily replaced (And available), etc.
Anyone have experience with this?
What am I getting into?
If you have one, how thick is the gauge?
Whoops! 1989 FLHS.
Thanks in advance.
Old Apr 25, 2016 | 05:41 PM
01fxdxt's Avatar
01fxdxt
Possible bad ignition switch
Old Apr 25, 2016 | 05:43 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Check voltage at the green wire on the starter (unplug it first).
If it's not full battery voltage then try the sticky above about adding a relay.
Old Apr 25, 2016 | 06:03 PM
zero-E's Avatar
zero-E
All great advice. Many times I have taken the switch apart and cleaned the gummy-ness
out and applied a very light coat of grease to the contacts.
Another thing seldom mentioned is gummy/worn out starter brushes.
Just a few more ideas for you....Lol...
Old Apr 25, 2016 | 07:19 PM
Crashone's Avatar
Crashone
Not sure if this will help. You may just need to clean and service the ignition switch.
https://www.hdforums.com/forum/softa...l#post14948606
Good Luck.
Old Apr 25, 2016 | 07:35 PM
98hotrodfatboy's Avatar
98hotrodfatboy
jump the battery cable stud on the starter to the starter solenoid connector. If it turns over it's in the wiring or switches. just make sure it's in neutral before you attempt it....
Old Apr 25, 2016 | 09:08 PM
RaSh's Avatar
RaSh
Thanks everyone, good info.
Crashone, thanks for the link.
kngfsh80
Jun 3, 2013 06:03 AM
Jokr99
Jun 29, 2012 06:13 PM
95 Ultra
EVO
37
Mar 18, 2010 04:15 PM
sharkaye
Shovelhead
Oct 17, 2009 02:51 PM
Beauregard
Jun 2, 2009 08:29 PM
