He told me he couldn't because the threaded plug stuck down the tube to far and the threaded plug is aluminum.
He is a real talent but, he had concerns as well.
Stainless steal tig weld. ??
Sacrifice the plug, slug the joint, make sure he drills several holes on each side to get a good weld between the bracket and the slug. From there, re-drill the mounting hole a bit oversized, mount the box using a bolt long enough to reach through the bracket and a nut on the other side.
Just went through this last year on my 97 ultra...the bolt plug is the problem with the setup. Found lots of threads on this and other forums with this same problem. ..always breaks at the bolt plug. If you still have the cb you will need to probably do as suggested and remove plugs reweld and just use through bolts like 98 and newer models do...I had already removed my cb so I picked up a take off braket from a 2007 in the classifieds for 30 bucks and bought some longer bolts.
