My 92 FLSTC Vision
Old May 23, 2016 | 12:08 PM
Sorg67's Avatar
Sorg67
Originally Posted by texashillcountry
Sorry man I gave my whole set up to a friend of mine a couple years ago.
That may be my challenge in finding a used part. Most probably stay together as a unit. Might have to pay up the $86 for the parts from Ronnie's. I suppose it is worth it even if I ultimately get an entirely new set up since then I would have a functional set up to sell or give to someone else.
For now, I think I will try to get the rack set up on the back so I can use the top case. For that my current limiting factor is a bolt that is too short.
Old May 23, 2016 | 01:14 PM
br549A1's Avatar
br549A1
I think I found them for you. Buy it now listing for $30.
https://www.ebay.com/itm/191867236789
Old May 23, 2016 | 01:46 PM
Sorg67's Avatar
Sorg67
Thanks kp877. These are really close, but I need part number 90346-90 or 90346-94.
I wonder if I could make these work? $30 for two is much better than $43 each.
Looks like the end that attaches to the bag mount would be fine. But the end that attaches to the passenger peg looks like the hole is too small for the '92.
Old May 23, 2016 | 02:02 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by Prot
For the badlands module, get the one that says it can handle parade mode. I have a part number somewhere but it might take some time to find it.
eBay is your friend for obsolete parts
Memphis Shades is great for the windshield although their instructions could not be worse.
A fresh set of rings, cosmetic gaskets, dynatek ignition, rejet the carb, install new Torrington cam bearing along with an Andrews EV13 will do wonders for the engine. I had my heads milked for slightly more compression and to get the combustion chamber volume to be the same for smoother running.
Hey Prot good advice there.... But can you elaborate on how you milked your heads? Lol.....
Old May 23, 2016 | 04:01 PM
Prot's Avatar
Prot
I milked them for everything they could give, even that last 3 horsepower!
Old May 23, 2016 | 06:20 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That's what they make drill bits for!!!
Old May 23, 2016 | 09:12 PM
98hotrodfatboy
I'm glad to hear some one found it cause I didn't......
Old May 23, 2016 | 09:32 PM
Sorg67's Avatar
Sorg67
I guess making due with what you can get is what you have to do with older bikes.
This one sold, but I found another a placed a bid. Hopefully it will work.
Old May 23, 2016 | 10:13 PM
texashillcountry
Dirt don't hurt
Good luck.
Old May 24, 2016 | 09:30 AM
Sorg67's Avatar
Sorg67
Wow - lots of old Harley parts on eBay when you find the right place. You could spend a lifetime and a fortune here.... Rut Ro, Rooks Rike Rubble......
