Strange leak!
Old Jun 8, 2016 | 04:05 PM
stephtell's Avatar
stephtell
Yes but I have replaced all of those...except for one...the quadseal...could that be the culprit?
Oh well, I'll take it all apart again this weekend...
Old Jun 8, 2016 | 04:14 PM
72fl's Avatar
72fl
Lean it against the shed on the exhaust side and see if it still leaks but it switches sides, could very well be a case leak, or it could be a trans leak, switch your trans oil to a red Auto trans oil and see if it is red oil maybe ?
Old Jun 11, 2016 | 09:08 AM
stephtell's Avatar
stephtell
Veni, Vidi, Fixed it!
Took it all apart again, fitted a new inner primary seal which I had originally mounted backwards (thank you Harley for reversing the fitment...) and I fitted a new quadseal which I didn't think of to replace before...
And it SEEMS this has cured the leak(s)!
Before it would start dripping as soon as I'd park it when hot, now it doesn't leave a drop!
Old Jun 11, 2016 | 09:47 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The newer design seal is marked "OIL SIDE" on one side of the seal...
Old Jun 11, 2016 | 09:56 AM
br549A1's Avatar
br549A1
I did the same exact thing and my seal wasn't marked oil side and the instructions that came with the seal and bearing didn't specify either. My seal self destructed then leaked. It took a lot of google searches to find an image with the wider bearing set up.
Trex
Jul 30, 2019 09:34 AM
tinsnips
Jul 27, 2015 06:03 PM
Panthers65
Dec 15, 2013 12:05 PM
Doug S
EVO
37
Mar 18, 2010 04:26 AM
Helitrash
Jul 31, 2008 10:04 AM
